BwoncoHowie
C-4 Wizard
- Nov 11, 2002
- 3,571
[quote author=digmy76 link=board=5;threadid=13627;start=15#msg130705 date=1052191588]
Donde esta las paliculas?![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
[/quote]
Hey digmy, congratulations on your choice of alts.
1G (Large Housing externally regulated)
I swear by this 1G large housing alt now. I'm about to build one to put on my pick-up truck too. The pick-up has 2 batteries so the test info I get from that will be interesting.
Let us know how yours turns out.
The best part is that it's Ford.
Delco alternators
There is nothing wrong with Delco alternators as far as the performance and reliablity that is engineered into them. I just think it would be embarassing to walk into a parts store and say I need a GM part to keep my Ford running. Then have to deal with all the questions, or… ha ha you should have bought a blazer. What about later on down the road when you sell the vehicle? The poor sucker who buys it will really be lost if he ever has to replace that alt again. I will not put a chevy part on any vehicle I own unless it's a Chevy car or truck. I guess I just can’t stand half breeds. Anyone who is that much in love with chevy parts, should sell their Ford and go buy a chevy. People always talk about easy wire hook-ups and eliminating Voltage Reg wiring. Easy is not always better in my opinion.
How about a 3G ?
The 3G is a powerful workhorse and is very capeable at pumping out the Amps. Many EB owners are now using it and recommend it. One thing I don't like about the 3G, is that the slip rings where the brushes ride on the rotor wear out too quickly. The slip rings on the 1G large case rotor are thicker and have a wider brush contact area. Also, the internal voltage regulator on the 3G is not as beefy as the externals that are available for stock replacement on the EB. Other than that the 3G would prolly be my second choice.
Here are examples where a 3G may be preferred
I have a 2G on my Thunderbird that came as factory equipment. The 2Gs are known to melt wiring or even catch fire if the wire terminals get loose where the Batt leads connect to the rectifier. So when that one fails again, I will replace it with a 3G only because the 2G is also internally regulated, and the 3G replacement is more compatable with that vehicle's wiring. If I had space limitations where the large housing wouldn’t fit very well, then the 3G could be a better option. The 3G has 2 internal fans, so if the external fan on a 1G or 2G gets in your way, or you prefer a smoother outward appearance, then the 3G may work out to be better for your purposes.
Sorry about the essays, I'm just excited about my results
BH
[/quote]
Delco alternators
How about a 3G ?
BH
