Yeah, that cowl design was not one of Ford's better ideas.
I understand leaving an open end for things to breathe and dry out, but that design captured way too much moisture and didn't promote drying well enough. And if you're living in a moister climate, it's hard for the sun to ever catch up.
What are you all doing in that regard when you fix yours? Do you leave the one (or both) open ends? Do you close them off completely? Or do you modify the concept and close those "water catchers" and open the cowl somewhere else to promote drying?
I'm thinking that even drilling big holes under the dash would have been a better solution. As long as water was not actively getting into the chamber it would not leak into the cabin.
But even with the existing design, water still makes it's way into the cabin!
Just wondering if anyone has changed theirs. If it were me, I'd seal it off completely, at least from the corners of the engine compartment.
That's where most rust starts anyway. Even before the floor pans get hit, the overlapping sheet metal starts it's downward spiral to rust-city.
Good luck with the fixes.
