Yep, I'm the idiot that didn't take good pics or measurements before deciding to tear things apart. Having issues getting my firewall and floor pan assembled somewhat close to where it should be.
I assembled my upper cowl, firewall and floor pan, but when I went to mock in my dash and E-Brake, I found a problem. I bolted my E-Brake to the firewall and it angled up too high to correctly attach under the dash. If I push it down to the correct level for the dash, it bows my firewall out and starts to lift the floor pan out of level.
From the diagram I have:
A - Top Cowl level
B - Front face of Firewall plumb at 90° and 7.5" top of cowl down to first bend
C - (where E-Brake attaches) at 74° and 6.75" to foot rest of floor pan
D - Floor Pan foot rest at 41° and 12.5" to the floor
If I bolt the E-Brake tight to the firewall and push to where it looks right, my angle of C is around 76.5°. The 2.5° difference pushes the brake up about an 1.5".
Can anyone out there compare angles/measurements to see where I'm off?
Thanks!
A - Top Cowl level
Thanks!
