Thanks for the input!A floor coating makes most of us around here nervous for what it was used to cover up. If anything...
But it does look like there was some rust on the floors, but from here it really does not look all that bad. Other than it may have actually gone through in some spots, it's not bad.
I wonder what the three new bolts are that are sticking through the body mount on the frame? Roll bar attachment point? Traction bar bracket? Some other exotic appendage that we can't wait to see?
Which basically means, keep the pics coming!
Regarding the floor coating. Whether it's bedliner, undercoating, or some specific specialized coating will dictate just how fun the truck is to drive especially in the summer.
In the hot weather most coatings do not keep the floor insulated enough. Especially if the engine has headers.
In the winter they let the cold in too.
In any season the noise transmitted through the floor is tremendous!
If on the other hand it's a specialized sound or thermal barrier coating, you might be in luck. Did the PO (previous owner in forum-speak) let you in on what was used?
Definitely keep the pics coming. We love pics around here!
It's a J-shift, which I think isn't too bad. I plan to do that and the floor shift conversion this winter.Nice Bronco, get the trans part repaired/figured out for sure before you go get a twin stick for it. Because depending it is a T or J shift xfer case, the twin stick job can be easy or hard.
The column shift is charming, but it just feels so disconnected from the transmission and has more points of failure. Plus the floor shift is just so much more natural to me... I am hesitant to cut the hole in the tunnel, but I'm 95% sure I'm going floor shift.Drive the 3 on the column for a bit longer before deciding to swap it to the floor. I (and many others) really enjoyed the 3 on the tree. I added a few new bushings and fiddled with the linkage on my last bronco and got it shifting pretty darn good.
For me, I'd either keep the column shifter, or look at a transmission swap/upgrade.
Looking at the inside of the truck, you have the under dash a/c and a huffy style center console. Putting a floor shift and a twin stick will be a little tricky with the limited room. You almost always need to heat and bend the shifters to get them in a spot where they will work. Also before I cut the big hole in the side of the tunnel for a standard shifter, I would upgrade the trans. stick with a standard pit an ax15 in it. That shifter fits well and its fun to drive. Go to automatic using a 4r70w or a 6r. Or go with the c4 and keep the shifter on the column . Nice looking truckThe column shift is charming, but it just feels so disconnected from the transmission and has more points of failure. Plus the floor shift is just so much more natural to me... I am hesitant to cut the hole in the tunnel, but I'm 95% sure I'm going floor shift.
Good point. I figured I'd lose the cup holders, which I don't care about (no eating or drinking in any of my cars!), but I wasn't thinking about the A/C clearance.Looking at the inside of the truck, you have the under dash a/c and a huffy style center console. Putting a floor shift and a twin stick will be a little tricky with the limited room. You almost always need to heat and bend the shifters to get them in a spot where they will work. Also before I cut the big hole in the side of the tunnel for a standard shifter, I would upgrade the trans. stick with a standard pit an ax15 in it. That shifter fits well and its fun to drive. Go to automatic using a 4r70w or a 6r. Or go with the c4 and keep the shifter on the column . Nice looking truck
So literally within the first five minutes I had people stop and ask questions - a couple town maintenance guys were driving by and stopped to watch it get unloaded from the trailer and ask about it, then a neighbor about 100 feet into the first drive. Then two more when I was on the side of the road today stuck in 3rd gear... I'm not really an extrovert, but will have to get used to it!
So I've been searching for almost 9 months and, after a couple margaritas on vacation, won an auction that I didn't really expect to... But overall I'm pleased with my first early bronco and think I did alright.
From my limited knowledge it seems like a solid truck with a few quirks and kinks to work out, including the ugly wheels and steps that will be the first thing to go! I'm sure I'll be reading and posting quite a bit on the tech forums. I haven't come up with a name for her yet, but here she is:
