FiTech/5.0 Explorer Install
jimschulz
Eastern Washington
Well, I finally got started on my Explorer 5.0 W/FiTech EFI started. I have pulled my 302 and am prepping the 5.0 for installation. Ill post pics as I go for those who have asked for results of the install. One question to all who have done the EFI conversion is what is the best way to supply the Hot in "Run and Start"? The existing ignition harness has two leads, one to the voltage regulator and one to the coil. The coil lead shows as a "resistor" wire (016) in my schematics and I dont think I want to use that one. I will be going to the Explorer 4G alternator and was thinking I could use the second hot wire from the ignition (904) as this ties into the new alternator. Any suggestions would be welcomed.
68stang73
That looks great! Take loads of pics and details. Videos too man. Ill be purchasing this system this month. Doing a frame off as we speak. Plan to have mine running on the frame by Feb.
bteutsch
For the white ignition wire, I ran a wire from the key switch where the resistor and I believe a green/red wire comes out. Then ran that wire to a relay under the hood near the battery. I ran the white wire to that relay. I did initially use the resistor wire and it ran fine, but I worried the voltage would be too low. You may be able to use this blue wire also that comes from the firewall if your bronco is equipped with it. Was for carb idle solenoid. Hot when in run and when cranking
bsquared
Hey Jim,
Looks like our engines are "brothers from another mother"! Nice looking build and glad I came across your post. I have my FI Tech all hooked up, but looking over your post made me rethink my whole wiring setup. I installed an MSD 6A ignition box when I did my 5.0 / 4G conversion and have run that box off of wire 904 (grn w/ red stripe) for 4 years now w/ no problems. I tapped my white FI Tech wire into that circuit, but now think that was a big mistake. Pretty sure it's only powered in the run position and it's also only a 16 gauge wire and I'm getting all kinds up undervoltage to the HP fuel pump during cranking. (down to 8 volts)
Don't mean to hi-jack, but I can't get my head around how to power the FI Tech white wire in both run and crank positions since these two circuits have to stay separate, right?
Bteutsch, can you explain how you set up that relay and did that enable you to power the FI Tech unit in both run and crank positions? I think I can leave my MSD box hooked up to wire 904, but I also need to figure out how to power up the white wire for FI Tech.
Jim, here's the thread that I started on my FI Tech install, in case it helps.
http://classicbroncos.com/forums/showthread.php?t=262164
Attached is the drawing from the explorer serpentine setup in the Tech Archives with my additions of the MSD box and FI Tech setup. (thank you, Gurus!) Since the FI Tech computer is powering the HP fuel pump, I definitely am not providing it with the power it needs to run it's stuff. Volts drop to approx 8 during cranking.
If there's anything I suck at, it's wiring and carburetors! (hence, this install) Let's compare notes and any help is appreciated!
Cheers, B2
bteutsch
I used a Napa Relay, I'll try and get the part number. Basically the relay needs a signal wire from an ignition source that is hot while cranking and hot when in run. I ran an 18 gauge wire from the back of the ignition switch for that. It's where the resistor wire and the red/green stripe wire come out of the switch. The relay requires power from the battery, it also requires a ground. Then the particular relay I bought has two posts that provide power to what you are trying to run. I ran the white ignition FITECH sub harness wire to that.
There is a terminal on the back of the ignition switch that is hot in both crank and run. I used the relay so all the voltage for the EFI isn't running through the key switch. But the relay is controlled by the key switch. On this particular relay there is only one hot wire out. On Napa relay AR274 there are two hot terminals that can be used.
jimschulz
jimschulz
Eastern Washington
bsquared, Thanks! I really like bteutsch's work around. I have plenty of bosch style 40/60A relays. One question for bteutsch is the terminal you connected to on the key switch a lug? or did you have to solder a connection? Its always a PIA to get access to the switch up under there. I already have 4 relays going in so a 5th wont be a big deal. I have a two speed electric fan and two fuel pumps, one from main tank that feeds the fuel command center, and one to transfer fuel from the aux tank to the main tank.
bsquared
Sure thing Jim. Since we're both trying to skin the same cat, I thought we should share notes.
Yes, that is good stuff from Bteutsch! At first I didn't think a relay would be needed, but with that HP pump (your fuel command center) drawing off the FI Tech system, it makes good sense. I already have a relay under my dash to run an air compressor, so I already have a 12v supply to tap onto for the new relay.
Progress for me will be slow, unless I can get to it tomorrow night or Thursday eve. Will post my progress here and on the post that I started. Thanks to all for helping! B2
jimschulz
jimschulz
Eastern Washington
After looking at the schematic for the ignition, the Green/Red-Stripe (904) wire should be hot in run and start with no interuptions. One thing could be the contacts in the ignition could be worn. Have you replaced your ignition switch, or is it original? I had to replace mine because it was completely worn out. I think Im going to use the 904 wire to trigger a relay that will provide 12v to the ECU, as well as control my relays for the fuel pumps and fans.
bteutsch
I had to solder a connection under the dash. I had to anyway because I had to replace the plug on the back of the ignition switch. The plug had melted at some point in the past. So when I was replacing the harness plug I added an extra wire in the connection. There may be some other wire you can tap into. I know there is a blue wire coming through the firewall on the drivers side that was for a carb solenoid. That wire would have worked if I had known about it at the time. Could have just plugged into that wire.
jimschulz
jimschulz
Eastern Washington
I see the blue wire you are referring to, but mine is a 69 and only has the three wires in that plug....Coil, Oil Pressure and water temp. I have decided to use the 904 wire from the ignition switch and run a relay with it.
bsquared
Yes Jim, I'm looking at using 904 for the signal as well. I'm concerned about the FI Tech orange wire that's supposed to be running the HP fuel pump / fuel command center. Found a pump similar to theirs (255 L/Hr) that says a 10 AWG wire is needed to power that unit, along with a 20 amp fuse. I'm concerned that the FI Tech orange wire meant to power the HP pump is only 18 or 16 AWG. Sent a note to FI Tech to clarify how they can run a high amp pump on a small AWG wire? Of course, I could just come off the relay and go straight to the HP pump, but I think their unit reduces power to the HP system to extend it's life. (necessary?)
My current plan is to use the AR274 relay (2 powered outlets) and run one to the white FI Tech wire and the orange wire to my HP pump, then use the other outlet to power my Carter P4070 primary off the other outlet. (if FI Tech says no problemo on the orange wire)
Can't remember exactly how I did it, but I know I "re-purposed" part of the 37 / 38 wire (10 AWG) to provide signal for the new volt meter in my cluster for the 4G when I did that swap. Then used the other half (38) for a 10 AWG wire to supply 12v power to a relay when I installed an on board air compressor later on. I hope to tap off that 38 wire to provide the 12v power side for this new relay and run both fuel pumps off that relay. Pretty sure both pumps can run off one 10 AWG wire w/ the signal coming from that 904 wire and I rarely (if ever) use the on board air compressor.
Might be over thinking it, but can't get around the fact they're using a 16 AWG wire to supply power to an HP pump that an exact equal says needs 10 AWG run to support it.
Anyway, many thanks to Bteutsch for the tip on the relay. Using it and running new wires to both my pumps should fix my undervoltage problem. I'll know more once I get under my dash and retrace how I changed those wires.
Will advise, B2
  • walbro_255lph_installation.pdf
bteutsch
I'm having an issue right now with the sub-harness power pin. The power pin in the plug has melted for a second time, after talking to Bryce, I was advised to add a relay for the orange command center wire. They think the orange wire powering the pump is pulling too much through the harness plug. They speculate I have a ground issue, but that a relay would solve the problem I'm having, and take the load off the harness. FITECH advised me that I'm the first to require a relay. It may be a good idea to use a relay from the beginning. But they apparently think it's not normally necessary.
bsquared
I was talking everything I posted above with a Big Bronco buddy at lunch today. He's also a pretty damn good mechanic and we both sell electrical stuff. (you'd think I would know more about this crap) That melting is EXACTLY what I'm worried about when it comes to the orange wire. It is undersized. (looks 18AWG and at best is 16AWG) That Walbro unit I referenced above is calling for a 10AWG wire, which is probably overkill, but can't be by that much. I'm thinking 12AWG to 14AWG will be about right, but any smaller can't be right for these pumps. The Carter P4070 installation instructions call for a 14AWG wire and draws less amps for sure.
I wrote to FI Tech about the undersized wire and have not heard back yet.
We discussed the relay upstream of the FI Tech unit like Bteutsch has described and that all makes sense now and should be fine to power the ECU / HP pump. My thoughts is that if I have any problems with the orange wire being undersized, I can run the HP pump directly from the relay on a second circuit and bypass the computer. I won't get have the advantage of extending the life of the HP pump, but I also won't have melted wires, connections, etc, right?
Will the computer freak out if it doesn't get a signal in that the HP pump is running? Guess I need to call Bryce to clarify, but that's the plan. Relay upstream of white wire and run HP pump off other wire. If any problems arise, bypass unit for the pump's power and run it separately from the relay to the pump. We'll see what the FIT Gurus say.
As far as putting a relay in and using the orange wire as signal, I don't think it's possible. Lowering the voltage on the signal of a relay will cause it to chatter and fail before too long, right? I work for company that reps ABB and Thomas & Betts and we see that problem on drilling rigs and in the plants. My buddy talked about that today as well and said no way / no how. Lowering the voltage on the signal wire does not translate to lowering the voltage on the power side of the relay, which is what they're after.
Funny thing, I already had another window open and was reading up on it.
http://www.appliancedesign.com/articles/91388-switches-relays-cut-the-chatter
I'd say that won't be a solution, unless I'm missing something. I'm going to be looking into powering the HP Pump / Fuel Command Center separately from the FIT unit and will report back.
Please don't judge that I struggle with electrical, yet sell medium voltage breakers and contactors. I'm just an oilfield hand that worked for Enron for 10 years and BS'd my way into an electrical sales job after the bankruptcy! (shows I can lay it on thick!)
Heading out there now to start pulling wires and re-route my fuel lines. Will report back!
bteutsch
Let me know what you figure out, as of yesterday's conversation with Bryce , he was thinking the relay with the orange wire was the ticket. Hopefully I'm not causing more problems by using the relay. I see what you are saying though. Because the other electrical connections are either on or off. The orange wire uses variable voltage to idle the pump when it's not needed. That variation in voltage won't transfer through the relay because it's either on or off?
Unless it doesn't feather the voltage? Could it possibly just be turning the pump off and then on momentarily to save the pump?
bsquared
Hey guys, I just spent about 6 hours going through my wiring to install the "upstream" relay to supply the FI Tech unit with sufficient voltage and spliced into what is NO DOUBT a 16AGW white wire that is supplying ALL the voltage that the unit controls. If you saw my rant about their wires being under sized, I was wrong. Their stuff is sized right and I got a nice dose of humility.
EDIT: Humble Pie served up by Bryce and I'm a dumbass! Got wrapped up in my undervoltage problem and forgot all about the pinche red wire from the battery, which is 14AWG and is supplying the power. Then the orange wire is also 14AWG, as well as the yellow fan wire, so they're all good. The frame pump only draws 9 amps and command center draws about 11amps (per Bryce), so the system should be able to handle those loads easy, which is all that is on the system. Sorry for the mislead.
Bteutsch, I'd still be concerned about lowering the voltage signal to a relay. Could be that the voltage drop does not get close to a point that would cause problems, but you might want to make sure of that. With a system engineered this well, they might have already gotten past that.
Alright, I'll untuck my tail from between my legs and go finish my install! Should be done today! Cheers, B2
Cheers, B2
68stang73
Cheers, B2
So its all good then with their existing wiring with command center? I just about aborted the command center purchase.
bteutsch
I'm sure it's fine, they would have had to change the design to fix it by now.
jimschulz
jimschulz
Eastern Washington
Got the 5.0 dropped in. Luckily I didnt have clearance issues with the serpentine brackets and the frame. I do however need to lower the PS reservior and mod the radiator brackets for the new reverse flow champion. Next I need to get the realys and harness done. Time is shorter than money right now, so it'll be a week or two before I get the harness started.
bsquared
Yes, 68 Stang, it's all good, especially with the fuel command center. I think I'm going to re-route my fuel lines back to the driver side to get better placement of my LP pump, HP pump and filters, so my install is going to take a few more days.
Jim, looking good there, man! Good luck on the rest of it and keep the pics coming! B2
