mrobert443
I have a 66 bronco with a 302 and I am considering getting a Fitech system or Holley system. I have been told the Holley system is better. I wanted to see if anyone had any recommendations?
I'll be doing Sniper.
I can tell you they are both pretty equal in the most basic parts of function. The fuel command center I would not use on either, if you cannot put a pump in the tank you will eventually have issues, there is a reason all new cars have them in the fuel tank, keeping them cool is hard to do otherwise. Now as far as tuning, I have installed many FiTech and like anything else you will have to learn their proprietary lingo and learn how to tune. None of the systems are fully self learning, they do ok but you will leave a lot behind if you do not get in and tune it to your specific application. I started with FiTech and took the time to learn their system and we like them. Holley is good as well but a few years behind FiTech in this particular market so they too will have some learning curves. I can tell you up front, 99.9% of all of the problems we have had to date with the FiTech system has been user error or an insufficient system to start with. Holley will be the same way. If you do not have a good running motor, leaky exhaust etc. EFI will not cure it in fact it will run worse so you must have a very solid base to put them on. No air or exhaust leaks is a must for both systems. To date we had one unit with a bad injector and they sent a replacement out and it cured the problem. Other than that no issues outside of exhaust leaks up stream of the O2.
Saw this and had to post - For whatever it is worth, the Fitech unit is supposed to be really good, but mine (right out of the box) had computer issues. Normally this would be something fairly easy to figure out with the company, but the customer service and warranty department of Fitech is the absolute worst. I have been in business for over 30 years and have never seen anything like this. My Bronco has been sitting for 3 months due to them not calling back, not emailing, not answering the phone and then taking my never-been used unit back to "test", but then never getting back to me. To this day, I cannot get them to give me my new unit back fixed or a new unit. If you want to discuss in detail, you can PM me. I would steer clear of these clowns.
thanks for all of the feedback. i think i am going to go with the fitech with the hyperfuel in tank fuel pump. i have been told to pay extra for the 600hp kit. will i need a new intake manfold?
Im going with the Holley Sniper, but my question is.... Do I need a phaseing rotor? and do I need a pressure regulator to run the Holley?
I have been hot rodding for 30+years. I always lean toward Holley. They have been really good to me.
