Fitting 37 in tires
NC-Fordguy
Bethel/Greenville NC
Guys...
I can get a set of 37x12.5x15 goodyear MT tires for next to nothing. This is one of those deals that's just to good pass up
What's involved in getting this to work on my bronco?
Currentley running 33's with a 3.5 suspension lift with fender flairs. No body lift. Don't have a clearance issue with the 33s nor any rubbing in turns.
I'm still wanting to keep decent articulation as my horse sees alot of off road
Ed
bax
Old Member
3'' body lift and your good to go.
kntr
Or a smaller body lift with Gorilla Warflares and a lot of trimming.
Rockrawl
San Antonio, TX
I'm clearing 37's with 5.5" susp, warflares and a pretty good chunk out of the inner fender. Probably going to add a 1" body to clear at full compression with the cage arms. I'd say its worth the effort, Bronco's look sweet with 37's :)
kontinu
mount holly
I have 5.5 cage coils up front, lift blocks in the rear and warflares cut out as big as I could go. no rubbing
Gummi Bear
Start trimming fenders and re-working the inner fenders. No need to lift it any higher; spring or body.
If I could clear 38" TSL's with a 2" BL and sagged out 35 year old springs, you can definitely clear the 37's with a 3.5" spring lift.
It depends on the amount of hacking you are willing to do and how much travel you are willing to loose.
For reference I run a run 33s with 3½" of lift. On level ground I could run 37s. But I flex a lot. That flex lets the rear tires rub the front of the wheel wells. I don't have an easy way to gain 2" of clearance. Lift won't solve the problem as it isn't the top of the wheel well that rubs. I would have to ditch the aux tank and stretch the wheelwell forward 2" just for that spot of clearance. That's just one clearance spot. Enough to make me not want to go that far.
Another case was a friends truck that went from 33 to 35. Didn't think it would be much of a change. They went on and he drove home. But it quickly became apparent that there was lots of clearance issues. I can't say he listed everything he did just to go to 35s, but I know there was new flares, body lift and severly dropped rear bumpstops. Probably several other things I just don't know of. And that is a tire with only 1" more radius.
Clint
Grand Junction, CO
I ran 37s with 2.5" susp and 2" body lift with NO problems. Lots of flex and never hit. Used Warflares and trimmed as high as possible. Now Im running 39.5s with only 1" more susp lift...
FerrumCampitor
Hutchinson, MN
I'm of the mind that you don't need any more lift, unless you just don't want to do any more trimming. If you don't want to trim, go with a 2" body lift and you should be fine. But for more stability if you're off-road a lot, keep it low and trim those fenders. Getting a set of wheels with less (or is it more? I always forget which direction is "back") backspacing to move the tires out will help loads with stability and help keep the tires out of the inner fenders.
GoFastCrackPipe
Salem area
I was running 37x14.4 tires and 5.5" suspension lift (no body lift) and only had to do minor triming... now that I'm running full widths, I have to do a lot more fender triming.
Doyle
Warflares with extreme install and if you're willing to alter the inner wheel tubs you don't really need anymore lift. I stretched my tubs, front and rear, and was running 35 x 12.50s on the stock springs with no rubbing. Could probablly have cleared 37s just by dropping the bumpstops an inch. I recently did a 3.5 inch lift just for the additional articulation. There are some pics in my gallery with the 35s on stock springs.
NC-Fordguy
NC-Fordguy
You guys who have done the extreme install with the fender flares what did you all do about the gas tank filler lines? Nearly every pic I've looked at on the net with this mod is always the passenger side of the Bronco.
BTW, the Bethel where I live is just north of Greenville NC in the eastern part of the state. Seems to be a few Bethels in NC
Ed
Rockrawl
San Antonio, TX
I made a new filler out of 2" steel tubing that runs from above the flare, inside the tub behind the wheel well and through the floor. Underneath the bed it bends to attach to the tank. The vent is just braided fuel hose. Both ends of the fill tube are the original ends, just hacked off and welded to the steel tubing. Making it was a PITA, but it works well and looks alright. If you're interested I'll take some pictures.
NC-Fordguy
NC-Fordguy
Pics would be of great help!!!!
Many thanks
