Iv'e owned 50-60 old Fords in my life and I've never come across that problem with a door latch. The nylon bushings that the rods fit into wear out and can give you extra slack.
Also sandblasting a door mechanism is the last thing Id do. Any grit left in there will greatly speed the wear process.
I didn't realize there was such a demand. It's one of the easiest rebuilds one can do! I would have made one when I went through mine if I had known people were interested.
I’ve media blasted dozens of door latches with zero problems. Just clean the media out good as suggested and lube everything up. I like to spray a very light coat of satin clear on the latch after it’s dry. Then work and move all the parts, then lube. Then reinstall.
I just fixed mine. Instead of bending the small tab I just welded on another small piece to the side of it to make it wider. That way it can’t slide into the gap.
I kinda agree with the not sandblasting comment. Maybe not so much for wear issues but for rust issues. As you have effectively removed all the plating that was protecting the metal. Another method for removing the grim is oven cleaner. Ive done it several times doesn't hurt the finish so no future rust issues.
