JR- Highly recommend the Baumenator for a couple of reasons:
1) Customer service is through the roof! Kevin (cant remember other guy's name) is awesome. Always willing to help.
2) Functionality- can do more things with it than a 40 year car really needs but some of the things are beneficial such as:
A) it can be wired so the upshifts are limited. I.E. like I mentioned in the previous post, you can flip a switch/ button so it does not go above 1st or 2nd. YES, this is the same as dropping the shift lever all they way done but my knees tend to hit the lever when it is that far down so it is a cool feature.
B) up to 4 different shift points. So you can settings for whatever you want to set up such as normal street driving, high performance, off-road, etc. You set the shift point rpm! Even my wife's Audi A4 only has 2 shift points.
C) If you run an electrical speedo, it has a single wire (tan) that provides the signal for the speedo (i.e. no need for cable). Also, this means that you can eliminate the speedo housing that would be required for a mechanical or VSS connection. The 2-3 inches saved by eliminating that housing helped make up for the extra length of my atlas (i.e. less of a steep driveline angle).
D) it can account for 4x4 low in the speedo. Flip a switch/ button and you can see that you're doing 2 MPH while climbing a rock!!! Ha
E) the wiring for the switches is ridiculously easy. Just run the wires to a 12v switch (i.e. power to one side of the switch and wire from trans harness to other side).
F) oh yeah, if you want to spend $1200, you can get paddle shifters for your steering wheel and shift like you're driving at Nuremburg raceway!!!
Honestly it is worth the money.
