Ididit or Flaming River column???
Merlin76
I am about to order a tilt column and need advice.... I am looking at either the Flaming River or Ididit, mostly because those are the only ones that I have seen in the parts warehouses.... Any others that I should be looking at? If not, are there any big differences between the two that I should be aware of?
T.I.A.
Buckin74
San Diego
I would choose the "Flamming River" hands down. Both are great products but the Flamming River seems to be slightly better.
Also if I recall, Iditit does not have an "Auto" version if you want to use a column shift.
M
Merlin76
Oh yeah, probably should have added that bit of info.... I have a manual, floor-shift setup, so no worries about the column shift. They seem pretty similar and both are $299... Hence the reason I am having trouble deciding....
77TexasBronc
Baytown Texas
Not so! Ididit does carry the Auto version. I have one that I am happy with however can not compare it to the FR as I havent seen one in person.
73stallion
Eugene, OR
depends on your wiring too. ididit plugs directly into centech, flaming river plugs into painless. the plug can be changed.
i have ididit in mine, but i used a flaming river 2 piece split mount because my column didn't want to go through the ididit one.
