Ididit or Flaming river column
trophybass
Plant City, Florida
I'm going to be ordering a new column in the next few days and i need some opinions and the pros and cons of each. Should i look at the Flaming River or the Ididit? I will be installing a new centech harness and i know that i will have to get a new adapter for my steering wheel but other than that is there one that is better or worse than the other? I also have a stainless Flaming River shaft with a spring in it that was given to me a while back and the guy told me it was for an EB but who knows, this is what it looks like:
http://www.flamingriver.com/index.c...ategory_ID=120/home_id=85/mode=cat/cat120.htm
Also is there a fancy column out there that doesnt tilt? Thanks, Alex
904Bronco
San Martin, CA
I have the ididit tilt column from BCB, it was powder coated black from the factory. I have had no troubles with it. ;D Easy to hook up to the Centech harness.
XT700
Brownsville
I installed the Flaming River column from WH. Very straight forward and fits great. Not very impressed with the turn signal switch, springs and detents seem weak, but it does function properly. Also installed Painless harness at same time, some modification required but not bad. I would use both again if I did another Bronco.
Cactus killer
The one from bc also comes with the column mount. It can also be ordered in chrome.
73stallion
Eugene, OR
just FYI, the ididit plugs directly into the centech, the flaming river you have to change the plug end. i have an ididit in mine and have been very happy with it.
brian72
Early Bronco Student
FYI - that is the shaft I have. You will have to get the column first...then order the shaft. They will need a measurement from the gear box to the column edge.
73stallion
Eugene, OR
also some columns have a 1" DD at the end, others have a 3/4" 36 spline. do like brian says so you can get the proper joint.
Imagator
Land O' Lakes, FL
I just ordered the same stuff. I went with the Flaming River Column and Centech harness. The FR Column is nice but I agree with XT700, the turn signal hardware seems a little weak. I havent installed the harness yet but it seems to be of good quality. The instructions are horrible! I wish I would have spent a little extra money and went with the Painless. From what I hear, Painless has very simple and easy to understand instructions. I have very little electrical experience so the instructions are very important to me. There is no way I could install the Centech by the instructions alone. It's a shame, they obviously spent allot of time and effort towards planning and assembling a quality, easy to install harness for the inexperienced guy, like me. Then blow it by including what are obviously thoughtless poorly written instruction.
By the way, Brian is going to help me with the wirring so let me know if you want to come by and take a look. I would be happy to give you a hand after I install mine.
trophybass
trophybass
Plant City, Florida
Todd, where did you get your column from? Also let me know when you are gonna rewire. I'll come help so that i can get some experience before i do mine and i can check out the setup. Alex
