Flash rust hubs
g8rb8t
Recently switched to front disc brakes on my 74 (great upgrade) I assume it's normal for flash rust on the new hubs after they are wet? See attached.
tcb-1
Shawnee, KS
Yep. If you didn't oil the surface or coat it with paint, fresh steel will flash quickly after getting wet.
Btw, are you going back with your original hubcaps? Love the stock rigs!
g8rb8t
g8rb8t
Running without for now. Got some Alcoas in the garage I might switch to. So what should I do at this point? Not painting them so wat kind of oil?
tcb-1
Shawnee, KS
What Bronconut said. Oil is only temporary. Clean the rust off with some steel wool and paint them.....
TwoDalesDad
You could go to...EASTWOOD.COM......THEY CARRY ANYTHING TO FINISH METAL WITH, ALL TYPES OF AUTOMOTIVE PAINTS...AND SUPPLIES....EVERYTHING IS HIGH QUALITY...
bmc69
"Flash rust"?? What dat?? Bare steel rusts.......always.
I paint my drums and rotors/hubs, calipers, etc with a light coating of red-oxide primer followed by high-temp engine enamel.
u10072
I've got a 9" Housing I sandblasted in march 2005 sitting inside an Arizona garage-- zero rust-- how you guys are car guys back where steel really rusts is beyond me :)
...Not painting them so wat kind of oil?
So is this some kind of ultimate restoration project then? Trying to keep it looking factory? Then it's going to rust. Those chassis/suspension components were rusty before they arrived at the dealer lot.
If wanting to maintain that factory-new look, I'd have to say some kind of clear coat or "cast-iron" look paint would be some options high on the list.
I've never done a religious resto, so don't have the answers, if there are any. I've always been more than happy with flat, satin and gloss black paint on just about any component under a vehicle.
Since a few pieces were painted black even back then, it looks good to my non-concours eye.
There must be some relatively unobtrusive treatments out there, one would think. What about that "Shark Hide" stuff that's being advertised a lot these days? Supposed to treat aluminum at least, but I get the impression it's good for most any metal. Maybe to a quick search for it.
Good luck. If a resto is what you're after, that's pretty cool. It's just got some pitfalls if you want to keep it that accurate, but also don't want rust on anything.
bmc69
"phbbbbttttt"!
All I gotta say. :p
Yeah, but just the process of sand blasting his housing has added some rust-resistance. If that had been a bare new steel housing still, it'd likely have some surface rust by now. Even in his area.
Not sure if the different media used in blasting makes a difference, but I would think so. Even just plain sand will do wonders for some surfaces though. We used to have blasted steel parts sitting out in the Salinas weather (lots of moisture) for extended periods that hadn't a hint of discoloration on them.
Don't know just how long that would last of course, because we weren't trying to push our luck. Just needed to store some things that got put on hold for some reason, while waiting for powder coating.
Normally a job got coated right after blasting, but many things (especially personal items) got "stranded" while waiting. With no obvious ill effects.
g8rb8t
g8rb8t
Looks like I'm painting them in the future based on the feedback. Definitely not an ultimate restoration, weekend cruiser ;-)
jckkys
Light rust holds grease and looks nearly black. Got some on mine they still look good after 36yrs. The 4x4 '78 hub caps cover all but about 1/2" but even that is hard to see. The desert climate helps too.
