Regardless of what you know, or think you know, or wish you knew...there is a change coming for motor oil.
I am not here to debate the merits of using flat tappet motor oil for flat tappet cams. That ship has sailed. But if you own a flat tappet Ford V8, Or a Cummins 6BT...be advised.
Current API CK-4 spec oil is shipping with the full ZDDP protection package for flat tappet Cummins in 15W-40 weight. Everybody thinks that Rotella, or Delo, or whatever has the right ZDDP package, but since 2020, it has ONLY been in 15W-40 weight.
As of January, 2027...the American Petroleum Industry, in collaboration with the Environmental Protection Agency and Major OEM engine manufacturers HAS AGREED to unleash API CL-4 to the market. This means that ZERO mainstream diesel motor oil will have the "requisite" protection for your flat tappet cam.
I am perfectly aware that Ford, Cummins, GM, Daimler, have all agreed to the change. I am also aware that ZERO testing has been performed by any manufacturer using degraded, contaminated, used, dirty, motor oil. (and yes, I am aware of the accelerated soot protocol)
So, if you want decent motor oil for your Bronco that meets the old spec in YOUR owners manual for SD or SE motior oil...this is your last chance is to buy some Rotella or Delo in 15W-40 with the CK-4 spec on the back of the bottle. Yes, you have to turn it around and read it. Yes, it has to say CK-4 in the little circle. Yes, that CK-4 gives you added protection that you can not buy in lighter weight oil.
It will take a few months for inventory to deplete, and since all of the OEM's say it is fully backward compatible, there will be both types on the shelf at the same time for a while.
If you want my opinion on why or if you want ZDDP in your Bronco, just tag me below. (or your Cummins.)
Or just google: "comp cams ZDDP catastrophy"
This is not applicable to any Explorer 5.0 or Mustang 5.0 roller cam engines.
