matt w
- Jun 12, 2007
- 2,799
Matt,
my 74 all stock motor did not come with a clutch fan maybe 76-77 might have I dont know. the fan you have looks like mine.
Are you running your tranny cooler before your radiator, after your radiator or divorced from the radiator.
I run my tranny cooler divorced from the radiator. my tranny never gets over 160 F
My motor I use a 180 thermostat and never goes over 190. It took a long time to get this rig to run cool. for over a year I couldnt get over Cajon pass at 220F It took alot of little things to make it work.
I run 4:11 gears on 33 inch tires.
1st OFF THANKS TO ALL OF YOU FOR YOUR INPUT AND HELP!
With that said the trans cooler runs in front of the radiator right b4 the hood latch.
Are you suggesting I relocate the trans cooler? Wow I'm good a turning wrenches but not sure where to relocate that puppy AND THEN HAVE TO RUN THE aluminum lines to the radiator!? Hmmm I "might" be talented enough to pull that off BUT WHY WOULD I DO THAT AND WHAT IMPROVEMENT WOULD I GAIN AS FAR AS TRAIL SPEEDS? Thanks!;>}
