Flexplate Torque Specs
Dyehard
I can't seem to find the correct torque specs for the flexplate to crankshaft bolts, and also should I put some loctite on the threads? BTW, this is for a 76 with a 302 and C4. Thanks.
Timmy390
Conway, AR
My book "How to Rebuild Small-Block Ford Engines states 75-85 ft/lbs using sealer on the threads. That's for both flywheel and or flexplate
I used blue loctite
Tim
