flooded carb
buckstone
los angeles, ca
i've got an edelbrock 4 barrel carb ontop of an edelbrock 289 engine manifold. normally, i park the bronco on a decline - that's just the way the driveway is. the other day, i parked on an incline - and after a few nights - the carb had flooded by itself. it took awhile for me to get the excess gas expelled. has anyone else had this problem with the edelbrock? it's calibrated properly - and runs fine normally. i'm thinking about getting a new carb. any suggestions? will need something that fits ontop of the 289 manifold. i do about 20% off road, 80% street. i hear that the quadrajet(?) carbs are nice. thanks.
Scott M
Baltimore
far as i know
its not an issue w/ where you parked (unless you were on a crazy steep hill, where it would do it anyway). and i don't know much about the edelbrock 4bbls, but i would assume its the same issue as it would be w/ any carb; probably got a little piece of something stuck in the needle seat. open it up, clean it out, and change yer filter too.
if i'm wrong, somebody will chime in to help ya out.
wildbill
Old Bronco Guy
;D ;D ;D As was said dirt in the needl seat or float set to high good luck. ;D ;D ;D Bill %) :p
