Curious to know how many people run with a floor liner, like Rhino, Linex, Durabak, etc. Vs. installing matting, like Dynamat, and a carpet kit. My PO Rhino'd the entire inside of the tub, which is geat, but even with a 2" BL, I still get a ton of noise and heat through the firewall and floor.
If I go with matting, it will probably be the adhesive Dynamat, with a Bronco house carpet kit over top. The only reason I haven't done it already is because I'm a little concerned about giving the carpert and Dynamat repeated good soakings, mud and dust coverings when I go off roading... which is primarily how I plan to use the rig - but I still want it to be comfortable to drive and for my passengers, which include my wife and two little kids. Will the Dynamatting and carpet hold moisture and start to stink and rust out my floors? Do they dry out relativel quick? In all reality though, it will probably not be that often that the inside gets totally soaked or muddy, as opposed to dealing with too much heat and noise every single time I drive her...
What are most of you running??
