Smokeater11
Guys I have good news. I might just get my rig running for the event!! I started at midnight last night, after work, and worked on it until 2pm today. I got the exhaust hung under it, 3 of the 5 gauges holes cut into the dash panel, got all the switches mounted, ran the speedo cable, mounted the alternator, put in the radiator and hoses, bench bled the master cylinder and changed out the fittings. I have the electric fan ready to mount and the master cylinder is ready to bolt on and plumb, then I can bleed the brakes. My carb is being rebuilt as we speak by a friend. Once I get the carb back and the throttle linkage and tie up all the wiring I should be ready to start it up. God only knows what kind of problems I'll run into once we get to that point but it'll still be nice to hear it run.
Plus while at the u pull it yard I picked up a set of Nitto Terra Grapler tires. 33x12.50x15 for $40.00. Not $40 each, but $40 for the set. Just couldn't walk away from them.......
