Baja71
- Oct 16, 2004
- 2,908
Search is not my friend today. Too varied.
I'd like to use synthetics where I can. Recommendations for Mobil 1, Lucas, Amsoil, Royal Purple, others?
Dana20: Calls for 50w, but some use 80/90w gear oil. Problems with that? Too thick?
Manual 3spd: Just calls for man. trans oil. Use 80/90w here? 50w, same as transfer case?
Dana44: I plan on using 80/90w gear lube for the diffs. Why would you use 80/140? Towing?
Ford9: Same as D44 with friction modifier for the rear.
Any suggestions appreciated.
