Flywheel - resurface or replace? (w/ pic of mine)
DanWheeler
Kirkland, WA
not sure if the close-up pic makes it look worse than it really is, or if it really is as bad as it looks.
thanks,
dan
bmc69
Wow. Having been low man on the totem pool in a machine shop for many years (read: get all the boring and dirty jobs..grinding flywheels included) and an engine rebuilder for 35.. I have to say that is one of the worst cases of heat checking I have ever seen. That flywheel is due for a replacement, I'm afraid.
astark
Bronco God
That is a very good pic, super bright, sharp and detailed. I can almost see down into the cracks and would agree with bmc69 and the others.
DanWheeler
DanWheeler
Kirkland, WA
thanks guys, i'm glad there's no doubt I need a new one.
I was looking on WildHorses and see they have a new flywheel but it says it will NOT work with old style 3-finger style pressure plates. I had already purchased a slightly used clutch from a friend and it looks to be what the description on WH4x4 is talking about.
Anyone know why this style won't work with WH flywheel? is there somewere else I can get a flywheel that WILL work with 3-finger pressure plate? I don't really want to buy another clutch and I dont really want to re-use the old pressure plate (diaphragm style) since it looks like the fingers are bent.
thanks,
dan
Viperwolf1
electron whisperer
thanks,
dan
I think the diaphram style clutches are smoother operating than the 3 finger. More consistent force on the pressure plate.
kelpy
I don't know why it shouldn't work. I have changed clutches from the 3 finger cover type to the diaphram (LUK) type a few times without changing the flywheel. The bolt patterns are the same.
You do need a new flywheel though - that one is shot.
Nobody
Stanwood
That flywheel is toast. If you're interested, I have an almost new flywheel that I bought from Toms. It's 164 tooth 28oz. $50.
I'd also recommend coughing up for the diaphram style pressure plate.
SC74
If you have it this far apart I would spend the extra money to get an upgraded pressure plate too. Those 3 fingers were ok back in the day, but the new diaphram ones are much better and will last you longer. Just my 2 cents.
