YNOTBOB2007
- Joined
- Oct 2, 2007
- Messages
- 216
I have a rocker switch with 3 terminals. The middle terminal has the hot from the high beam switch. The top terminal has the wire to the foglight relay and the bottom terminal to ground. When I turn on the foglihts with the switch (high beams on), the foglights turn on but the illuminated rocker switch goes out. When I turn the rocker switch off, the foglihts turn off but the switch illuminates. This is the opposoite of what should happen. I tried swapping the wires on the top and bottom switch terminals but that blows the inline fuse. What am I doing wrong? Thanks in advance!
