Nowik35
- Aug 27, 2018
- 201
So I just took the cap off the T2613 distributor and I'm not an expert but based on Google the guts look like a load o matic. I attached a picture. I also took a picture of my 1904 and it has a vacuum advance nipple, but no SCV valve. So I'm totally confused now. Is the nipple on the carb not for the vacuum advance?Here's some more info on the SCV/"Load-O-Matic" distributor - From what I can tell your new distributor is NOT a Load-O-Matic and the 1904 probably doesn't have a SCV - look at the pictures in this article to see if your 1904 has it or not. This is good news because the 1904 & T2613 carquest should work together.
https://fordsix.com/ams/load-o-matic-distributor-spark-control-valve.28/
I'd start by plugging off the vacuum from the carb and setting the timing at around 10 degrees - plug in the vacuum line & see if she runs & adjust it from there.
Good Luck & keep us posted on your results.
https://flic.kr/p/2pRC4j2 https://flic.kr/p/2pRDaVP
