Ford 9" help in St. Louis
triracer67
I picked a 9" spool with 5.69 gears, 31 spline. I got a set of 4.30 gears and 28 spline spool with it. I'm looking to take it apart, install new gear and 28 spline spool, and reinstall. I can remove and replace the 3rd member, but have never torn apart the 3rd member apart and rebuilt. I'm looking for some help in the St. Louis area, I want to do the work, but need an expert to guide me through the process. Send me a pm, or reply. Thanks!
OB Bronco
Orange Beach
Go to bad shoe productions an buy the video. It's $20-$30 but walks you through it. The guy who makes the video is a 30+ Ford Tech/Mechanic. He makes it easy. Plus he has a Facebook site you can ask questions on. Kenneth Collins is his name.
Timmy390
Conway, AR
Built my first Ford 9 3 years ago using this as guide.
http://www.ford-trucks.com/articles/ford-9-inch-rebuild-gear-setup/
Bought the needed tools at Harbor Freight. I bought my own 20 ton press ($149 as I recall) because it's $30 or more to get a bearing pressed off and another $30 to get one pressed on around here.
I suggest you go with a "solid spacer" when you put it back together. The solid spacer eliminates the cursh sleeve so no huge force needed to start the curch. It also makes changing pinion seals quick and easy in the future.
Tim
70_Steve
Old Guy
Never mind setting up a 9" (which is probably the easiest to set up)... My question is why you would install a 28 spline spool? Do you have some 28 spline axles you need to snap???
Stay with the 31 spline spool and pony up for some 31 spline axles.
Read this article. It's what I read before setting up my 1st 9". You will need a dial indicator with a magnetic base to measure backlash, and a beam style inch/lb torque wrench for setting the pinion gear preload.
hucklburry rev2
I was waitin for Steve to chime in. I went to Steve's shop and did all the labor, he checked me as I did both the 9" and the D44. I chipped in for that bearing puller he bought for his time, great way to spend a day! Thanks again Steve!
