Ford Transfercase ident? (time sensitive)
PsYcHoBrOnCo
Fort Worth, Tx
I have a 74 f150 here at work, it has a divorced TC....is this something I might consider keeping? Or is that particular model not useful for us?
No real value to a Bronco. There just isn't enough room under the rigs to fit that much length.
PsYcHoBrOnCo
PsYcHoBrOnCo
Fort Worth, Tx
I guess I should of asked...1: what TC is it and 2: I'm guessing this is not one that would be used in the 205-203 doubler set up.
toddz69
Interesting that a '74 half ton (should be an F100, not F150) would have a divorced t-case. The half tons usually used a D21 single speed behind the 435 4 speeds. If it's an automatic, it likely has a fulltime 4WD? and would be a NP203. The F250 3/4-ton trucks used the divorced D24 2 speed transfer case. They had about a 2:1 low range iirc and aren't desirable for the Bronco for any reason.
Todd Z.
PsYcHoBrOnCo
PsYcHoBrOnCo
Fort Worth, Tx
Todd Z.
Awesome Todd, thank you....
