Hi, getting a couple of different spray outs is a good idea. Many body shops mix their own colors and if you know who is going to paint the Bronco they should be able to zero in on a color. There is a lot of variation even in stock colors with the same code. They should be able to show you literally hundreds of color chips.
If you have something like a helmet or other item that is the exact color you want a paint supplier or good painter should be able to match it. If you are going to add metallics or other additive the color will be different from the color on your item.
Good luck
