Found a ZF trans
Bronco73
Cape Coral, FL
Today I went to the recycler to buy a throttle body of a core motor and I look over and there sits a small block ZF 4X4 transmission. It's missing the transfer case and shifter.
This may make some of you cry so hold on for the best part. I can buy this thing for $100 and if I want them to rebuild it then it will only cost me $450. Monday I will be going back with a $100 to buy it.
Now since my EB is up for sale I am thinking of installing this trasmission in my full size centurion bronco to replace the C-6 so I can get an over drive gear. Does anyone know if the ZF will fit in an 89 full size bronco? I am concerned that it will hit the underside of the floor. If this is a problem then I just may go with the Mazda version which he has as well but I didn't get a price.
What's your thought on changing the C-6 to a 5-speed.
Past_Miner
First of all, you got a screamin' deal. If he had another one laying around I'd consider slapping it on the plastic and having it shipped all the way out here this afternoon.
I don't know if it will fit in an '89 Bronco. However, it should fit in an '89 pickup. So I would say that your chances are good. If it hits the floor you can always install a 1" body lift, or cut the hump and modify the top side. Personally, I would stay away from the Mazda version. I've never had good luck with one of those.
Sounds like a fun project, good luck.
rjlougee
It'll fit very well. Bolt right up to the engine and the T-case will go right on the back. Your biggest issue is going to be the removal of the hydraulic line to the clutch slave cylinder.
DO NOT pick the Mazda over the ZF. The ZF is designed as a HD tranny, the Mazda as a poor half ton unit.
Oh, and if you decide you don't want it, I do, seriously. Shoot me an email if you don't get it for yourself.
Joe
Bronco73
Bronco73
Cape Coral, FL
My other post listed me as an guest? I think that happened because I was cleaning up the temp files and all. I forgot to log back in.
Thanks rjlougee for the info on the fit. For the price of the transmission I don't think I can pass on it and I think it will be worth my while to try it out in the Centurion so I will more than likely install the transmission after a rebuild or a good go through and drive it to see if I like the 5-speed over the C-6. I like the auto but I need an OD gear. Driving at 3k down the highway is a bit much. But if I choose to remove the 5-speed then you will have first dibs on it. I plan on trying to get all the parts by xmas so I can install the 5-speed while I am off for two weeks.
As for the pedal swap I have an auto so I need to get pedals anyway. What year pedals do I need? My father installed a 2 wheel drive in is 85 truck and I will call him today to see what he did.
Anyone have a flywheel and block plate for sale that will fit the ZF?
fox
very good choice, the mazda five speed is a huge pile of crap, it's the same one that they put in the older explorers. they are a magnesuim(however u spell it) case that wears out. the bearing races get slopy and the transmition barks grinds and all sorts of other horible noises, and they cost an arm and a leg to rebuild. definitly stay away from them in the future...
but you got one hel of a deal i fell out of my chair when i read that(i really did lol)
Bronco73
Bronco73
Cape Coral, FL
Well th shop was open today so I picked up the 4X4 zf trans and to top it all off I got it for $90 instead of $100. I had a core 4R70w case so I gave it to him for scrap and he gave me $10 for it. What a good day. Now I will look for the parts I need to complete the conversion at the Columbus swap meet tomorrow.
I remove the PTO covers and it looks great inside. I am a very lucky man. I only went there for a throttle body which I ended up not using.
