Found Trans fluid in D20 Transfer case
motoman
Phoenix, AZ
Hey guys,
Broke my D20 output shaft during Christmas vacation....so I've been saving for the Wild Horses hardened output shaft assy with speedo conversion..... the install went very well!!!!
Well with one exception... when I pulled the fill plug to check the oil level a mix of 80w and trans fluid came shooting out.....
I am trying to wrap my head around this and get it taken care of tomorrow. I have the C4 with the T D20... do I pull the Tcase and adapter to get to the correct seal (the one at the tail end of the tranny?)
http://shop.oreillyauto.com/ProductDetail.aspx?MfrCode=SKF&MfrPartNumber=14978&PartType=768&PTSet=A ??????
I read in other post to get a buddy to help so it doesn't land on my chest when I take it out. Do you have to completely remove the cross member to get it out????
TIA!
motoman
motoman
Phoenix, AZ
What's the large O ring for??? I think that is the right tail shaft seal i found at checkers... but not familiar with the large O ring in the link you sent.....
garberz
Bronco Influencer
Conejo Valley, Ca.
That's the O-ring for the bearing retainer that fits into the adapter housing, you'll have those two pieces apart when your getting to the double lip seal.
Mark
Viperwolf1
electron whisperer
The Checker part is not right. The Bronco C4 seal is unique to only it.
You only need to pull the tcase off the adapter. The bearing retainer will stay in the tcase. The o-ring seals those two together and tends to hold the retainer in. Wobble it out, remove the snap ring and input gear, remove the large snap ring, tap the spud shaft/bearing out. Then you have access to the seal. Reverse the order to install and don't put the input gear on backwards.
motoman
motoman
Phoenix, AZ
Ok... so I (Tim and I) pulled the Tcase down..... I ordered the Oring and double lip seal from BG... while I was at it I ordered the Master Rebuild Kit.... it's long over due and hopefully when we get done it won't pop out of gear on the freeway.....
Thank you for the help.... can't wait for the parts to get here.... more soon...
Viperwolf1
electron whisperer
Put some new detent springs and balls in it while it's out.
