Jr.mudflinger
Could I replace my stock 3 on the tree that's hooked up to my stock 170 I6 with a Ford 4spd top loader from a 1966 Mustange coupe? Any imput?
-Colton T.
-Colton T.
The six cylinder 3 spd box itself is a differen't length than the V8 box, it is approximately 1 inch shorter.
But that isn't the issue.
The output shaft and adaptor length are different. All the conversion pieces out there are for a V8. So you will be looking at doing a V8 length transmission in all likelyhood. That pushes the transfer case back about 3". This is how it is done when swapping a NP435 into an I6 powered Bronco.
I don't know if the toploader output shaft can be shortened 3" to use the I6 tailhousing. It might, but I am doubtful until I see one. As far as I know it would be a first, and that is not that common with a Bronco.
It will work for your 3.8 swap just fine but for the straight 6 he would have to move the crossmember. as the tranny probably wouldnt reach the engine if you try to keep the corssmember in the stock location.. Shouldnt need to shorten the spud shaft. its been awhile I cant even remember how long the inner splines are but I would want as much spline contact as possible.
-Colton T.
Ranchtruck: His stock little 170 just isn't going to be able to use the overdrive.
