Big Slim
- Dec 11, 2007
- 339
i am building my crossmember for the ZF and is a little strange that my numbers are off. the driver side of the crossmember is dropped 1 inch for clearance for the driveshaft. so if even i would see an inch difference in the vertical drop on the side pieces. once it is mocked up i am only getting 1/2 inch difference in the drop on each side. everything measures level. is the drivers side frame lower than the passenger side? that would explain why its a 1/2" off. i am assuming it was symmetrical. using the stock mounting holes.
