Frame Cleaning Equip/Tools
aaronbodell
Olympia
Okie Dokie.
So the frame up project begins in a couple of days, and the first thing is the clean up the nasty, gunky rusty frame (which appears solid, yay!). So I need a best of equipment list for frame cleaning. I share what I have, and if anyone would like to make suggestions - please please do!
Commercial Power washer -
Angle Grinder 4.5inch 110v (suggestions on wheels?) -
3/8 Power Drill 110v and Cordless (wheels?) -
9MM Gloves (not firearm, unless we need to put it down and tell the kids the bronco went to live on a farm).
Dremel Style Tool with various wheels -
Eye and ear protection -
Fire Extinguisher, just cause -
First timer here, so all feedback welcome. :D
Patrick.M
Greenville, SC
Unless you're hell bent on doing it yourself I would take it to a blaster. There's a guy around here that will do the whole frame for $150 in a day. Shop around in your area.
It'd take me several hours to strip a whole frame and still wouldn't be able to get to many of the hard to reach areas.
If you want to do it yourself I would recommend a knotted cup brush and some long pants :)
bknbronco
North Metro, MN
Ya the blaster guys wont want a nasty greasy frame! Id start with a 2" putty knife and scrape it all down, then pressure wash and scrape more. Then id hit it with a wire brush, either with one in a drill or just by hand would work fine. Get that grease and grime off! Maybe hit it again with the pressure washer then drop off for blasting.
I went to a small guy blasting place, and got my frame and both bumpers done for 150 i think. It will come back way cleaner than you will ever get it!
Make sure you take the time to get the clumps of dirt and bee hives out of the frame tubes!
Heres some pics for insperation! I went with POR15 prepall, paint, and chasis coat because i wasnt set up to spray at that time, but now that i have the equiptment id just shoot epoxy on it.
aaronbodell
aaronbodell
Olympia
Thanks for the feedback, definitely a clean frame. I noticed you had shock hoops placing for dual shocks all round. I'd assume that you'd want to weld those up after prior to the POR 15 (which is what I'd like to use)?
u10072
Yep get the chunks off and the grease and then have it blasted. To get anywhre near the job of a blaster you will spend a FULLLLL day with a wire wheel if not more and it still wont be as good as a blasted frame-- much less you don't save that much money-- Just blast it.
bknbronco
North Metro, MN
I welded everything on prior to the blasting, so that everything got blasted. I also beefed up the frame around where the steering box bolts. If i had to do it again i wouldnt use front hoops, but instead the f250 mounts.
aaronbodell
aaronbodell
Olympia
Great stuff.
So...
1. Pressure wash and degunk.
2. Weld shock mounts front and rear.
3. (AOD/AODE incoming) Weld tranny crossmember back 1.5 inches, or is that a bolt on?
4. Find sandblasting source
5. POR 15 and accompanying clean/prep stuff.
Missing anything?
half cab
Guru Bronco
bknbronco man thats a smoooth clean job you got goin there for sure...
bknbronco
North Metro, MN
Not sure what you got planned for shock mounts, but i wanted duals all around. Duals now adays is old school, and every time i bring up dual shocks on here i get thrown under the bus! You do what makes you happy, but might consider just one nice shock per tire instead of the duals i got. The f250 front mount seems the popular choice, but not sure what these guys do in the rear? Just stock rear mount maybe.
If you havent braced up the frame by the steering box look into that. Its way easyer to do it now than when the truck is together. I also bent the crossmember in a bit and rewelded it to make room for the new bolt pattern if i decide to go with a power steering box. I also welded on drop trac bar mounts, but you might not want them either.
Tig welding to the frame is impossible as i learned. Stick is the only way to go. No matter how well i preped the frame for welding the TIG just wouldnt weld worth a crap with that old crummy frame metal. The stick weld worked and looked ausome in comparison to the TIG. Not sure how a wire feed would work. (In the first weld pic you can see all the pin holes from the TIG. I ground out that weld and we layed new weld over it with a stinger hooked up to the TIG welder and stick welded it as in the second weld pic. Much cleaner)
Just do all your thinking now! Do it right and do it once!
Use epoxy, its better than POR in my opinion.
I agree with that also. I would use epoxy now because im set up to shoot paint. When i did POR it was my only choice, and it was easy to brush on.
u10072
personally-- its better to start perfectly clean-- I would just degunk, blast, then do all your welding. I have never tried it be a friend who can TIG said the bronco frame has just so much crap in it -MIG really doesn't have any issues.. just get it clean is all. Before you divorce the frame from the body-- I would HIGHLY advise you to mock up everything, just tack weld everthing and then blast. That why when you have everything all good to go you don't have to hope than it all fits properly. Its much easier to weld also while not having the confines of the body also. POR15 is a nice product but its such a pain in the ass--- personally I would epoxy it or just simply use Rust Bullet. Just easier to use and once the frame is all pretty its not rusting out unless you make it your daily driver in the in snow.
u10072
Duals are perfectly fine and work GREAT just as long as you aren't driving fast over rough terrain for long periods of time. I would just recommend an adjustable. Adjustable duals are a really nice ride and will help the handling and ride. Go fast and thats another story.
aaronbodell
aaronbodell
Olympia
New plan then...clean, blast, mock, weld, epoxy. The frame was already off when I got the rig, so there's that. Only have access to a MIG welder so that's my option. Haven't got a spray setup yet for epoxy but that sounds like fun, so need to figure that out and look at epoxies.
Regarding the PS box weld up, there are some pretty nasty welds supposedly to firm up the PS pump frame area, but I'll see how bad they are compared to bknbronco's, which look pretty darn solid. Great pics, thanks for those.
On my previous '74 EB, I had dual front and rear shocks from Duffy in 2003, and that 3.5 inch lift bounced me around like crazy but it handled pretty well. Really for this build, it's all about streetability. Even a cut bronco with stock suspension and 31's would have plenty of offroad capability. I just thought the dual shocks would improve ride on street, could be dead wrong there however.
Oh, and I'm a contributor now (or shortly once they see the payment), so pics incoming. Maybe go for a full blown build thread!
Thanks!
Aaron
bknbronco
North Metro, MN
Atta boy! Money well spent! For every hour i spend in the garage i probably spend 4 hours on here! I like learning through others mistakes!;)
Everybody now adays are all about single monotube shocks like a bilstein. There spendy but you only need one per wheel. There probably 100 to 150 bucks a shock and there made how soft or firm you want them. I should have gone that route and probably will, but for now im going dual doetsch DT3000 all around. Maybe save your time and money welding the dual mounts and hoops on and spend that on a single better shock?
Build your bronco how you want...just wish i had went a different route on mine last summer. None of the lift kits the venders sell are really up to date with what the guys are doing now. Things have changed in the last year or two! Do a search on here on the F250 front shock mount and ull see.
Good luck and have fun with it!
rmcbama
Birmingham
I had my frame blasted and powder coated. I believe the blasting part cost about $100. If you have it blasted then you paint it, make sure you get all the sand out of the frame left by the blaster. I had stood mine up at a steep angle before blasting to get all the nests and mud inside the frame out. Took a while to get it really clean. I don't plan on a lot of heavy off road so coating was the best option for me. I still have sand coming out of the frame almost every time I move it.
Another thing to consider is painting the inside of the frame. There's several threads on this forum that talks about it. A lot of people used a rag and rope to coat the inside. I didn't see a lot of need for this but it's something you may want to think about.
bronco-kid
roanoke
i got a sand blast attachment that hooks to my pressure washer from northern tool ,took me about 2 hours and 4 bags of sand .had my frame down to bare metal .think the blaster cost about $50 sand was about $5 a bag.
aaronbodell
aaronbodell
Olympia
That's a really interesting option. I'll take a look. So far, I've pressure washed the outside, and have started in on the frame using a 2 inch wire wheel on my 3/8 drill, which works okay, but is slow going. I bought an angle grinder and a 4.5 in twisted wire wheel, but for some reason it came with threads, so I can't lock it down between the two retaining nuts. I'll have to figure out that as well. Found the original VIN, which was really cool.
bad 68
Northest Washington
you don't use the retainers that came with the grinder. just screw the wire wheel on the grinder. Sand blasting makes one hell of a mess. I would pay the $100-$150 for some one else to clean up the mess.
POR15 is a rust converter. If you don't have rust you don't need it.
asinor
Tulsa, OK
What sand did you use for blasting media that cost $5/bag!?!? The cheapest I can find is $0.50/lbs for crushed/ground glass.
i just talked to a guy a couple of weeks ago and he will sandblast and spray it with epoxy primer for around $250. That is what i plan to do. I am also going to take him my front and rear axle housings at the same time to him.
That is sooo worth it. I'f I ever do a frame off, I'm taking it to someone.
