Frame cleaning, prepping for paint
mattt
When I started my project, I never gave much thought to how the frame looked. It has surface rust, crusty 40+ years of age on it. Now that I'm at the stage of making the Bronco look more presentable, paint soon, I've decided the frame needs some attention. The best way to clean up and paint the frame would be have it blasted and powder coated, but I'm further along in project status that the prospect of tearing it completely apart for blast & powder coat is out of the question.
Over the last few nights, I've been getting after the frame with a 4.5" twisted wire wheel and it's cleaning up good enough to hit with spray paint. Problem is....it's very slow going, messy as hell....think rust dust dirt cloud hanging over everything and there are areas I can't get the grinder into. A lot of what the grinder is removing is ending up on me...but I am taking precautions, dust mask, goggles, etc.
What I'm wondering is if anyone here has come up with a better way to clean up an assembled Bronco frame in prep for a simple spray paint job?
Some sort of product that could be applied and rinsed off would be sweet....I know I'm probably dreaming, but I figured I'd ask the Bronco brain trust as I've seen many a good idea here. Thanks in advance.
BRONCROB
WISNER LA.
The wire wheel and time work well.I don't know of anything to spray on and remove rust.A steam cleaner will get a lot of the crud off if you have access to one.
nickgp
It's an ugly messy job. Zep purple degreaser, pressure wash, scrape, repeat. Wire wheel. After two days of this it should be pretty presentable.
welndmn
Some oven cleaner and a pressure washer will remove all the chunks, but you will still need to attack it was an abrasive disc, either sand paper, fiber, or wire wheel
cldonley
Robinson, TX
x2 on the Easy Off. You can save yourself grinding on a lot of dirt, but ya still gotta grind on the rust. Good Luck!
Crawdad
I used simple green and let it soak but it has to stay wet, doesn't work very well when dry. I also used a $100 power washer. Did a great job and didn't remove any of my paint. If it did remove paint that told me to fix that area again. I used a lot of hard bristle brushes. I removed what rust I could with a 2" sanding disc on a Dotco. Lastly brushed some POR 15 and went over it with good rattle can stuff. Use something under the POR 15 bc you will not get it off your cement floor!
M
mattt
All good ideas, especially the oven cleaner, forgot about that option....thanks for the suggestions! My frame is dry, not gunked up with oily, greasy residue. It has no cancerous rust, just a flakey, rough rusty finish on the surface that comes off as a dust when the wire wheel hits it. I'd hate to have to pull out a dremel or equivalent but with the body on there are just places the grinder cant get into. Thanks again for the suggestions and keep them coming :thumbs up:
dave67fd
If all your looking for is what paint to use, POR15 is your best bet for painting over rust. It's designed for it and is what most use when short of sandblasting or stripping the entire frame. It comes in aerosol, isin't cheap but is the best on the market.
M
mattt
Thanks for the suggestion on the POR. I've used it on other projects in the past, but not on the Bronco. I'm looking for things that will speed up the frame prep and/or make it less messy. I think the wire wheel is just going to have to be done...as slow and messy a process as it is. I've had very good luck with a particular spray paint that Krylon sells......it's called Rust Tough. It goes over clean metal or rusty metal with no primer.....so far so good with it. Biggest problem is it's hard to find on the shelf. Only place I've found that stocks it currently is O'Reilly Auto Parts. Lots of places carry Krylon, most don't carry the Rust Tough.
73azbronco
Put it on a trailer, take it to a self car wash, apply liberal amounts of easy off oven cleaner, inside frame as well, spray the mess off, take to sand blaster. $350 blasted, $15 in Easy Off, $5 in coins for wash.
Then I had a shop paint it, but if you can do it even better.
I used Eastwood internal frame spray rust preventative, which was also very easy once frame was cleaned off.
On a clean frame I would avoid POR15, it actually works better on a rusty surface and needs to have the frame etched on a clean frame. To much extra work for me.
M
mattt
I wish it was that easy on my end, but currently it's not ;)
M
mattt
As I cleaned up the factory rear shock mount with the wire wheel, I had a discovery and a question. Is the washer and bushing that is showing in the pic part of the shock mount assembly, or are both pieces just so stuck in place from being there probably since 69 or should they both slide off?
If they do come off, I need to replace the bushing....notice how it's rusted partially away and tapers thin.
dave67fd
That washer you see is part of the shock. I don't believe the shock bushing is frozen there and if it was you wouldn't be able to get a new one on (with the bushing). In other words it isin't fully threaded, and It looks correct as is. It just looks like some of the material is rusted off the boss where it looks thin. I wouldn't say its a show stopper. If you have access to a welder you can add some weld material to it to build up a bit but again probably ok to use as is.
M
mattt
I looked at the repro rear shock mounts as well. Are the repro shock mounts made exact copy of the factory? I ask because I've seen it many times before where the shock bushing gets stuck on the shock mount. One time in the past, I had to cut one off another vehicle....I cut it long way then peeled it off the mount. Anyone know with 100% certainty how the factory mfg. rear shock mounts were?
The cupped washer really had me thinking it was a washer that came with some set of shocks from long ago, but it appears to be as stuck in position as the worn bushing. I'm not super worried about the thin bushing, but it would be good to replace if it can be persuaded off. If it comes down to add welding material, I might just leave it. Thanks for the advice.
73azbronco
the rear stock mounts are solid bar, the repros are hollow tubes with a threaded rod welded into them.
M
mattt
The more I look, the more I think this is a shock sleeve/bushing that is stuck in place on the factory shock mount. Notice in this pic how there is a defined step up in diameter right after the threaded area ends.
Most shocks that come with rubber bushings also have a metal insert/sleeve inside those rubber bushings. I suspect what is shown here is one of those metal sleeves from a long ago shock. I'm hoping someone knows definitively. It's been this way since I bought the Bronco 15 years ago. As I've upgraded shocks, I've just slid the shock rubber bushings on over what was there. The washer was just stuck in place....came off when grabbed with large vice-grips.
Rustytruck
Doesn't look like a sleeve to me. If it was a sleeve the threads would run under it.
M
mattt
Ok, maybe not a stuck-in-place shock bushing sleeve.
Riddle me this, when you buy new shocks from any Bronco vendor, do you have to remove the pre-installed bushing sleeve to be able to mount the shocks to the Bronco? I have no experience with new, off the shelf shocks because I have Fox Shox on the rig.
dave67fd
Although your mount looks like a sleave it is probably from slight erosion at the threaded base giving the perception that it is a sleave.
No metal bushing or sleave is required on the top mount. They are only used on the bottom mount for when a bolt passes through it.
The aftermarket shock mounts are very close in design to the original. Duffs are much better quality (welds and finish) and a better fit than JBG's. Don't know about the other vendors. Tube or solid they are more than adequate in strength for a shock mount.
Not all shocks have them installed. If installed, they are usually application specific and fit a specific mount requiring them or they are provided with them for the user to install if needed.
