With all this time on my hands from COVID I have been finalizing my build plan. Im starting a frame off build and am planning on getting the Blue Print 306. I have some questions and I'm hoping some of you guys have done what Im planning:
BP 306 Sniper EFI
4R70W (with Quick 4 Controller)
Stock Dana 20
Explorer Front Serp
32" Tires
3-1/2" suspension lift
PS, PB, and all Disc Brakes
Will be using for 95% street driving
Here are some of my questions:
-What kind of issues come up with the 306 to 4r70w (flex plate, balancing, torque converter, etc)
-Does the 306/4R70W fit under the hood without a body lift? My plan is to not have one as I don't like the big gaps in the front/rear but Im willing to go with a 1" if it will make things easier and fit better.
-What kind of header options are there for the 306/4R70W? I was looking at the TBP long tubes but do they work with this setup? I heard there can be some issues with them fitting around the tranny. Also they can't be used with P heads so is that an issue with he 306? Anybody deal with this?
-What gear ratios for the front and rear with the HP/Torque of the 306 and gears of the 4R70W?
-I know the explorer serp is not a direct bolt to the BP306 but what exactly has to be changed (balancer, timing cover, etc)?
-Best ignition box and coil for this engine? What other wiring does this set-up need other than general car harness?
-Any other issues that might come up that y'all have dealt with(aside from the hundreds unknowns that always come up from these builds)
I have done a lot of research on all of this but can't find detailed answers and solutions. Hopefully the best classic car community on the web can help me out.
I know it can be hard to type out all of this so PM and I will give you call if that's easier for some of you and you're up for an old fashioned phone call. Appreciate any help y'all can provide.
BP 306 Sniper EFI
Stock Dana 20
Explorer Front Serp
32" Tires
