If media blasting or chem dipping the frame, what kind of alternatives do you have for stopping the rust inside the frame or is it worth worring about. This is a problem ive often thought about.
Chem dipping will get inside the frame. I am not sure what "chem dipping" really consists of--as it can vary from shop to shop. At the Redy-Strip here in Indy, they can blast, they hot-tank, they have a chem bath, a lye bath and an acid bath and they also have furnaces for baking paint, etc off. I believe they also do electrolysis. When I talked with them, there wasnt a set process...it varied by project and how thorough you wanted to be. I talked to them about dipping my tub, but it was alot more expensive than another shop that specializes in various media blasting. Plus, he was very clear that despite the multiple dip process that you might not rinse every bit of chemical from seams and such which cancause paint problems later. I used them for blasting my frame and axles...and later for my cage and bumpers...as they had quick turn around times. However, IDS (Indianapolis Dry Stripping) is the place to take the body and panels; they did a fantastic job, but lead times are long.
Ideally, a shop that does electrolysis would be a great rust/paint removal option...same for the body...no harsh chemicals, no heat generated. It would probably be a bit of a mess to skim afterward, but perhaps a quick blasting with nut shells or such would work well. Its just finding a shop with a large enough tank that isnt cost prohibitive.
As far as inside the frame, there really isnt much paint and crap that needs to be removed usually. With blasting, a shop can/will run the hose up the frame rail a bit. The galvanizing process is a full dip into molten zinc; it chemically/molecularly bonds the steel and builds a film thickness that can vary depending on duration of the dip. It totally covers inside, every nook and cranny. Hence, why you wouldnt want to use it on an axle housing that accepts races and has tight tolerances...the film thickness really can throw things off. In many cases you need to re-tap holes afterward. It could be done on a housing, I suppose, but would require some machining afterwards that would make it cost prohibitive. The galvanizing process, as Nick mentioned earlier, I blieve, does include a couple of dips; one usually in acid--this is typically a relatively short dip that is meant to "clean" any surface rust or slight oxidation from the pre-blasted, new or otherwise stripped steel. It will not reliably remove paint, heavy scale or many coatings. The piece then goes into one or more rinses and finally into the zinc bath. Its a cool process to check out in person sometime, actually.
As well, if any of you are considering hot dip galvanizing...take a look at your frame, if there are any closed tube sections (shock hoops, roll cage support legs, etc), then make sure you drill two holes that "closed system" (~3/16"-1/4") on the work being dipped. When anything sealed is dipped, the "cell" of air is super-heated during the dip to 850-900 degrees...any closed tube, boxed steel or sealed system will burst and could really make for a bad day on your project. The idea is to drill holes at the highest and lowest points so the air has a place to escape as the piece goes in and the zinc has a place to exit/drain as the work is raised out. Apparently, its not pretty when a "closed piece" makes it into the vat.
