frame straight enough?
scrubtopdoc
I just picked up a 1968 bronco and have the frame stripped clean. I see no evidence of damage or repairs anywhere on it. It only has surface rust except for a 1/2" hole in the driver's side frame rail just aft of the shock mount. I checked the measurements based on info from this site (thanks!), and all of the diagonal measurements are spot-on. But when I set the frame on the driveway, which is flat concrete, the passenger side frame rail sticks up about 5/8" at the back. I cant find any frame service around where I live that will look at the frame; they require that it has to be an entire rolling chassis before they can put it on their frame machines. So my question is whether this amount of deviation is acceptable, or does the frame rail need to be straightened?
Pops68
Bronco Rookie
Bazetta Township
Have you tried repositioning your frame in different directions/locations on the driveway and rechecking your measurements?? Chances are your driveway isn't perfectly flat/level.
Just a thought???
S
scrubtopdoc
Just a thought???
I will try a few other directions just in case. I have a 8-foot level that I used before I set the frame down and it was reading level in both directions without any obvious low spots. I am just wondering if that amount of difference matters enough to try to have the frame straightened.
Steve83
Set the frame on 3 jack stands, so it's impossible for them to twist it. Put the front one under the center of the front crossmember so it's not twisted by being off-balance. Then use your level across the frame to check if it's twisted when there are no external stresses. If so, simply stick a couple of landscape timbers across the frame at each end & under the low spots on the other side, and twist it back with an assistant who weighs about as much as you holding the other timber down. The frame ISN'T super-strong, so it shouldn't take much - especially if the timbers are >8'.
The one I measured to create the diagram wasn't twisted enough to worry about, but it had several other subtle bends that I straightened. Read this page & the NEXT several:
(click this text)
