ELECTRICAL BUMMER, The story begins a year ago when for an unknown reason my coil exploded. Thinking it was a bad coil I purchased a new one and within an hour of driving that one also cooked. Frustration set in and I decided to buy a Malory unilite distributor, new coil and just to be safe I also replaced my alternator. All was well for a year until today when the bronco stopped running. After diagnosing that there was no spark from the coil wire to the distributor I went and purchased another coil and blast resistor. After install it fired right up and I started driving home. 10 miles down the road it died. Again the coil was cooked.
I have a 74 302 running a Holley EFI system and AOD trans. The alternator is a 130 amp G3 (I believe) and as per the Mallory distributor installation instructions I am running a blast resistor between the coil and the distributor. Painless wiring harness. No electric fans. Its a very basic system
All the lights and electrical seem ok, no hot or melted wires. After the bronco was towed home and sat for a couple of hours, I put yet another new coil in to see if it would start and I reinstalled the original blast. It did but only ran for 10 seconds or so and then went back to no spark. I am reading 3 OMS from terminal to terminal on the blast so I don't think its bad. Could this issue be the voltage regulator on my alternator?
Is the coil burning up due to a spike in volts and if so where could it be coming from? Alternator? Ignition? Gremlin? HELP!
