70_Steve
Old Guy
- Dec 13, 2002
- 8,317
Like the title says...
I had been thinking of using this as an opportunity to "upgrade" to the T-bird calipers. Since installing my hydroboost, it's been very apparent that my stock rear drum brakes are locking up before the fronts, which are stock 76 Dana 44 disks. The eventual plan is to upgrade the rear to Explorer disks but the driver's front caliper decided to start leaking now...
To help make the decision, does anyone know the diameters of the stock 76 caliper piston vs the diameter of the T-bird pistons? I'm thinking that if the combined area of the T-bird pistons is significantly larger, then installing the T-bird calipers will only make my current brake bias problem worse. Yes, I am planning on installing an adjustable proportioning valve at some point. Maybe just do that now and get it over with?
I currently have the stock 76 proportioning valve installed. If I install the adjustable valve, should I simply remove the stock valve??
