ilovemaui
I have '74 with D20 and C4. The other day when I tried to lock in the front the diff the front wheels were binding. The rear tires turn but the front wheels would not rotate. To test a few things I removed the front drive shaft and put the tcase in low with the rear end off the ground and the tcase is turning. I jacked up the front end and locked in the hubs and I can turn the wheels by hand and I can turn the driveshaft no problem. Put it back together and the same thing, the front wheels keep binding. Looking for suggestions.
I have a 3.5" lift with extended front drive shaft from Tom's.
