- Jul 4, 2016
- 791
I've been working on my Bronco for 4.10 years, and I hope to have it running in another month. YA! The Dash is almost painted and then I can start on wiring.
In the mean time, I have been picking away at some items and I found that the front original drive shaft is binding at the rear Cardan joint, closest to the D20 yoke. Yep, I've already broken off the zirc fitting in the U - joint that I got from Tom's. I replaced all the U joints awhile back.
SO, I measured out all the angles according to an old CB article and made a diagram (I think it is according to Tom Woods). I have angle issues I think. I'm not sure what FORD'S original angles were supposed be for the drive train, if you know, please share with me.
Lets start with what I have:
Wild Horses 3.5" Suspension Lift with a 1" Body lift as well. Original D44 modified to handle a F100 steering box mounted on the inside rail, with custom Tie rod over steering set up from Ruff Stuff. And a custom RAM. I measured the Caster today by putting an angle finder on the flat spot on the bottom of the lower bushing of the "C" knuckles and came up with 2.5 degrees. That seems exactly where I wanted the front end, and I like how the Drag Link and the track bar are almost parallel. Y, the pitman arm needs to be twisted just a little more, haven't heated it up to do that again, but I will get to it. The engine is in, so most ot the weight is in the Bronco, though it might squat some more with gas, roll cage, gear, myself, etc. That would decrease the angles I have now that are extreme.
Looking at the the diagram (driver's side), my Dana 20 sits 5 degrees down tilt toward the Ford 9" rear end. I have the rear axles perches cut off, so I can rotate the rear axle to whatever I need to for that perfect pinion angle. I have not set that up yet. But my main concern is that with the original front Drive shaft that I rebuilt with the universal joints from Tom's with zirc fittings, how do I go about decreasing the angle of the front yoke on the Dana 20? I'm binding on that 1st joint of the Cardan universal joint closest to D20, and I'm not at maximum droop yet.
I have those heavy duty motor mounts from Wild Horses, but they seem to be sitting in the lowest point of the frame motor mount saddles. Could I grind on those oval openings to lower the engine down an inch? Will the engine actually slide down the cradle more? Which would tilt the drive train down in the front, thus improving my angle off the D20 towards the Dana 44 and the front drive shaft? OR do I get the original motor mounts? do they ride lower, i.e., situate the motor lower in the cradle?
Or do I shim the transmission mount up? This seems counter productive as it would not change the angle of the drive train much, yet increase the height difference between the D20 and D44...I'm thinking not.
Or do I spin the pumpkin on the D44 upwards to achieve a better angle, yet it is only off by 10 degrees, will that improve it much? By spinning the yoke upwards, I decrease the difference in height between the D44 and D20, decrease the angle between the front drive shaft and the D44 (10 degrees down to what 5 or less), and I would think I decrease the angle (14 degrees) between the Front drive shaft and the Dana 20 front yoke. I don't like this idea because of all the fab I have completed on the D44 for my tie rod over set up with Ram assist steering, the custom track bar mount and lifted frame stops.
Or do I send all these readings down to Wild Horses or Tom Woods and ask for a high angle special front drive shaft that has extended radius angles due to their XC splines that allows greater articulation? Are these as strong as a regular set up?
Here's the real crux of the matter, is it a better design to rotate the pumpkin and hopefully get the angles within the original FORD tolerances for the front driveshaft, OR can I buy the high performance high angle front drive shaft and expect to be able to get the same performance out of it with those high angles?
More info: I'm running 4:56 gears in the axles, 36" tires, the original C4 transmission that has been built for the close to 400 hp I should be able to get out of my 5.0 roller with Sniper and trick flo heads. There's a good possibility I will be on granite slabs on the Rubicon since I live in that county. Original trac locs are in axles. And I like to go down the road at 65-70 mph, so I'd prefer not to have a noise or vibration from these guys. Might switch to an atlas later....
How good are those High angle front drive shafts, and am I in their tolerance range?
Does my front springs look ok to you? They have that characteristic bronco bulge. I am running 7 degree bushings in the radius arms. I've seen the adjustable radius arms that BC Broncos sells, but I think that if I used those to rotate the D44 axle I would improve my D44 yoke angle but cause a bigger problem of wrapping the the springs more and ruining the nice 2.5 degrees of caster that I have measured. And I would ruin all the connections for the RAM assist, the track bar mount, etc.
I'm pretty sure I put the "C" bushings in correctly, but I have included pictures (I mean, C'mon man, they say top on them). ;D;D;D
Please, any opinions from the advanced suspension front end guys is very appreciated. And thanks to all the guys that have helped me in the past come up with a steering geometry that should be bullet proof when done.
Forrest
Forrest
