pipeline010
- Nov 15, 2017
- 618
Hey gang. Got some multiple questions for a planned project:
Truck:
1969 with Electric Wiper Blades (I think this matters, actually).
Dana 30
After finally completely finishing (until it breaks again) the rear differential with new seals, bearings, flush, brake hardware, and some SS brake lines, I'm moving forward to the front diff and need some info.
I literally have zero first hand knowledge of the internals of the front differential. My knowledge of differentials is limited to the ford 9", of which I've become very confident.
My front right seal has been leaking for a while, though, and getting harder to ignore which is precipitating this project.
Question 1:
What size drums do I need for the front end? It seems the midpoint for thicker drums falls in the middle of the 1969 year. The electric wipers came onto the trucks about halfway through the year, so I thought it may be correlated. How can I tell the difference? Part Number for rep?
While I'm breaking everything down I intend to:
1. put some MM hubs on (because I'm sure the stock internals are a disaster).
2. Replace both ujoints with some heavy duty spicers.
3. All new drums, shoes, hardware, self correctors.
4. Replacing hard brake lines across diff with SS lines.
5. Replacing inner/outer seals (yes there are outer housing seals in the d-30).
6. Obviously cleaning/flushing the interior. May even throw some diesel fuel in there and turn the axles to get the carrier flushed before redraining.
7. POR-15 the housing and all free components and adding a topcoat for the UV.
Question 2:
How do bearings work in the front end? I'd like to replace the bearings as I did so for the rear axles on both sides. I'm having trouble wrapping my head around which bearings I should replace and where they are? Are there two sets INSIDE the hub? One set on either side of the carrier, are they all easily swapped (removed and replaced) or am I getting into more than I can understand? A little clarity on the bearing stuff if anyone can explain it to a newb such as myself.
Question 3:
Anything else I should definitely do while I'm in there?
Question 4:
Any random advice for my first go at this?
INFO:
When my rear popped the drivers side seal due to failed bearings in the spring it took me 6 days to complete the project due to incompetence. My other bearings failed last monday and the truck was driving again by tuesday. Would have been same day but I needed to wait to use the press at work. I'm great mechanically, but need to EFF up a project every possible way before I can wrap my head around it.
Truck:
Dana 30
Question 1:
Question 2:
Question 3:
Question 4:
INFO:
