kevinv
Hello,
I'm getting clunking noise when in 4wd. I'm assuming this is coming from the front end. It happens when the front hubs are locked and in 4wd. It doesn't happen with locked hubs but in 2wd. It also seems to happen under load, its worse when accelerating and lessens when letting off the gas.
I was attributing it to a transfer case problem until I read some of the posts on clunking. Seems it could be a drive shaft problem. The truck has been lifted but the driveshafts weren't replaced. You can see a lot of the yoke (sorry if I don't have the terms right). I have been told the driveshafts should be replaced because they are over extended.
Is it more likely to be the driveshaft/u-joints over a transfer case problem? Any other suggestions for determining the problem would be appreciated.
Thanks for any help,
Kevin
Kevin
