I probably found it on pirate back in the day but no clue where to find it now. Around 75% is what I've followed.Good stuff.
Is there a ratio available somewhere upper to lower lengths?
This is correct, however in real world experience, as long as the upper link is horizontal at ride height, it really doesn’t matter. Even some OEM set ups have the uppers 60% shorter than the lower. It’s about packaging and having the upper link near horizontal to pointing up slightly toward the axle at ride height. from there, link lengths and the necessity of the ratio from upper to lower quickly diminishes and it then becomes about packaging. Even my own truck the upper is 50% shorter than the lower on the front for packaging, I needed it to add caster at full bump so the drive shaft would clear the starter. Geometry needs to be within a certain window but packing rules and there are usually ways to cheat it to meet a packaging issue.I probably found it on pirate back in the day but no clue where to find it now. Around 75% is what I've followed.
Brian, let’s get the rear of mine 4-linked and then we can start designing 3-link front setups for both our rigsSimilar #s to the "unubtainable" ideal 4 link #'s (well, some of them anyway on a short, narrow EB).
I've always wanted to 3 link my Bronco. Steve's got some good experiences with the differences for real world crawling and I want to try it.
The only front 4 link I did was about 60% and was a flex monster plus it handled pretty well. There's a lot of wiggle room.This is correct, however in real world experience, as long as the upper link is horizontal at ride height, it really doesn’t matter. Even some OEM set ups have the uppers 60% shorter than the lower. It’s about packaging and having the upper link near horizontal to pointing up slightly toward the axle at ride height. from there, link lengths and the necessity of the ratio from upper to lower quickly diminishes and it then becomes about packaging. Even my own truck the upper is 50% shorter than the lower on the front for packaging, I needed it to add caster at full bump so the drive shaft would clear the starter. Geometry needs to be within a certain window but packing rules and there are usually ways to cheat it to meet a packaging issue.
I’ll have the same issues you do.Tim- I've already measured... lol
I have motor mount clearance issues which are easier to re-design than notching frames again!
Yeah, on mine with so much up travel it creates a major re-design, like non-existent motor mount! lolOn an EB motor mount is always in the way.
