I used stock replacement tie rods from Jeff's. It steers straight and bumps don't affect it too badly. It's hard to describe but if you were driving and just made a quick jerk back and forth once (as if you were checking the steering) it will feel real loose as if the truck was gonna roll, The faster you go the worse it feels. We didn't have this problem before I did the swap. Also there is play in the steering that wasn't there before. The alignment shop didn't give a print out or description of what was done other than adjust toe-in. Whether or not you can help, I do appreciate all input.Thanks, Mark
But I will make a suggestion to anyone thinking about buying used parts to do a swap,Buy the kit from Jeff's. I have over $700 in buying all the new parts when the kit cost under $600 I bought the used parts on this site for $200 and replaced everthing exept the knuckles, spindles, and calipers
