front end shimmy ??
mtkawboy
Billings Mt
Ive got a shimmy right at 37 mph. Any faster or slower and it goes away. Kingpin bearings, track bar bushings & wheel bearings are all new. It does have studded snow tires and I havent checked for a bent wheel yet. Tell me I dont need to buy the $240 front tie rod please. It has the one end built in and the other end removable. It has a stabilizer on it. Its not scary but you can feel it and it annoys me. Any ideas or suggestions? This is in 2 wheel drive high. Guess Ill have to jack it up and see what wobbles on it
dpmerrill
Springville, UT
Hey Kawboy,
I have lost a tire balancing weight before, and it only vibrated at around 40 mph. I realize, ball joints or worn bushings are the more likely cause, but it's something to hope for...
M
mtkawboy
Billings Mt
Dana 30, no ball joints. Everything in kingpins is new, all bearings & seals set to correct preload per specs
Rotate the tires first.
Then change the C-bushings for something with more caster in it.
Do you have a lift? You did account for the loss of caster when it was lifted didn't you? Anyway I have never heard of any problems with having too much caster in a bronco.
M
mtkawboy
Billings Mt
I dont have a lift but it has the original C bushings in it and I have a brand new set of Duffs waiting for it to warm up some more. I checked the wheel bearings & kingpin bearings for slop today and everything was good. Wheel runout was good and no sign of missing weights. Everything is tight so I greased it and will drive it for now. Ill try rotating the tires and see what that does for now. Tires are a little out of round so maybe thats it too
68ford
measure your toe-in, might be to much mine did something just like what your talking about.
