natureboy300
Hey guys,
been a while since ive been on. Been working 2 jobs for far too long and now its deer season, so time is at a premium ;D . Hope everyone is good and well.
I had done quite a bit of work to the Bronco a few months back. I put in a WH 3.5" lift, a track-bar riser bracket, front disc brakes, and bullet proof steering. Before all that I had symptoms that resembled the death wobble, and found that to be a wasted drag link where it connects into the tie rod. I had some Rancho or super lift front springs in there before that were stiff as hell. The bronco drives like a dream now other than at about 50 miles per hour the front end starts to vibrate, and the faster I go the worse it gets, to the point where the steering column is shaking a bit. When I did the brake conversion I put in all new wheel bearings, and have rechecked them since. I had all the tires rebalanced, and a front end alignment done so I could get the actual readings and see how close everything still was. Everything is within specs other than the castor, which was a little on the low side. I wouldnt think that would cause it but I may be wrong. Any help would be appreciated.
NB
NB
