Front Fenders?
byson1
Nashville
Ford OE:)
Seriously though, there are two varieties out right now, one with a thinner mil steel than the other. Unless someone knows more than I they are all made overseas and by the same manufacturer. I realy think it's hit/miss as to fitment but have heard much better things about the newer, thick sheetmatal ones. I've got a pair of thin ones. The PS fits good, DS not so good.
Baja71
Go with the thicker mil, they are slightly thicker than stock. The thinner ones may be slightly thinner than stock. DC, Tom's carry them. Any fender will need some fitting, OEM or aftermarket. Aftermarket may need a little more coaxing but it's the luck of the draw.
white 72 bronco
St. Charles Missouri
I got a set from Dennis Carpenter and only the drivers side fit was even close. Passenger side body line was 3/4 inch low. I called Bronco Graveyard and he said his would fit so I ordered a set and they were perfect!
baglock
are those with the built in flare and how does it look....any pics installed?
Its the stock reproduction fender. Not cut. Pic's in my small gallery after a back yard paint job.
