Front Jeep seats in a EB ??
coupe66
Cedar Park Tx
Anybody run front seats from a 2011 Wrangler Rubicon Unlimited ?
Arikilen
Clovis, CA
I don't know about the 2011. But there seems to be a lot of guys on these forums running seats from that which shall not be named vehicle.
Anything is possible with a little fab work. Make sure that you compare their height to something you know. Especially if you are a tall guy.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
I've used two non stock sets of seats in Broncos over the years. Typically, the passenger side is quite easy to get to work with stock EB Brackets. The driver side always requires cutting and welding to get everything to line up.
As was mentioned, the thickness of the seats could be an issue - especially if you are a tall guy.
coupe66
coupe66
Cedar Park Tx
Looks like they will work and they don't look to bad either. Pretty comfortable too. I just won't say what they came out of. ;D
Tedster100
Chairman of the Bored
I bought a full set of Jeep TJ seats for my build years before it was completed only to find that there was no way those seats would work for me. Too high. Stored for 6 years and ended up selling them. uuggggg.
Pearlcoat
I have Jeep super seats in a 77. Bought them new years ago, the drivers side has split a little bit but lasted a long time before that happened. The material is waterproof. The drivers side fit good, used the bronco seat hardware. Had a guy fabricate a bracket for the passenger side to mount on. My better half is 6'3" and the seat works OK for him, at least as much as it can for a tall guy.
The only thing I don't like, and may not be on newer Jeep seats, is the adjustment for the seat back is a turn dial rather than a lever, like most cars. Its a bit of a pain if you like to adjust the seat very much.
