68ford
- Dec 26, 2004
- 2,710
the lower mounts are the regular mounts on the radius arms, closest of the 2 to the axle. the top is a basic shock hoop with a bar going over the engine.
i run a 12in travel 2.5diameter sway-away coilover, with 250lb over 350lb springs. compression valve shims are 0.015 and rebound valve shims are 0.010.
you can set up the height however you want, what hasworked best for me is having ride height be midpoint of the travel, 6in up and 7in down.
if your only going to run coilover and no air bump, i would stiffer valving, mine is real soft. and if your not using all the shock travel at high speed, and heat isnt a problem, you could run a 2in diameter like the rock crawl guys.
mines about 3.5 to 4in lift.
