Front Side Marker Lenses DIRTY :(
74midnightblue
DA U.P Michigan
Help my Front Side Marker Lenses are DIRTY!! The dirt is inside the lenses of course. I cant seem to get the lenses off the sockets. I soaked them overnight in soap and water but the dirts still there. I have done so much work on my bronco I would hate to see little things like dirt in the side marker lights on my rig. I want to take the lenses off the sockets but that plastic is thin and looks like it would chip easy. Thanks
Tito
CB Fire Starter
Bakersfield, CA
I just got a new set of lenses and bezels, I think its like $75. Tom's and JBG have them. I know what you mean about putting dirty or aged parts on a clean restored rig.
Viperwolf1
electron whisperer
Use something like a small bottle brush or pipe cleaner.
ol gray mare
Put a little bird shot from a shotgun shell with some soapy water in it and shake it. Don't over amp it , but it will clean it in short order.
As you found, the lenses are actually part of the socket/housing. Sonic welded most likely. So "glued and screwed" is what you are there in this case. Like you thought, unless they're ready to fall apart all on their own, you'd probably break something if you tried to pry them apart.
They WILL come apart, but usually not without carnage.
Let us know if anything you try works to get them clean.
From past experience with my '79, I decided to remove the side markers on the Bronco, when it became obvious it was going to be sitting for awhile. Those ones from my pickup came apart no problem unfortunately. All it took was a few years of sitting while the moss growing inside expanded enough and the lenses just popped right off! Nasty little bugger, that moss...
Kaptn Obvious
Austin
I assume you're speaking of the running lights just inboard of the headlights. I'm Bronco illiterate. The 77 in the garage doesn't have any side marker lights in the front.
The fronts on the project have seal snot seal snot dripping out of them Aside from that they look decent. I think the plan is to go to clears and they're headed for the parts pile... Shoot me a PM if you want them. I'll need to clear it with the boss first, but I think she'd happy to see them go to a good home.
Sounds like a PO has replaced your front fenders at some point KO. The '77 would have had amber colored side markers along with (vertically oriented for your year only) the red ones in the rear.
Most (if not all) replacement fenders come without the cutouts for the lights, so a lot of people don't bother cutting them in and re-installing the side markers. Buddy has one on the driver's side, but not the passenger side, which had been replaced.
