The problem even professionals face when using the normal methods for finding something loose (jiggling by hand, or even using a prybar) do NOT always work acceptably well on the larger and typically tighter components of an old 4wd truck.
I've seen guys test for worn trackbar bushings what way and miss completely worn out sets!
A couple of other things to make sure of first though. Check the air pressure in the tires. Most tires fitted to an EB (especially larger 16 and 17 inch types) have higher load ranges than needed and do NOT need to be at their maximum rated pressures.
Most around here seem to settle on between 28 and 32 in the front, and 25 to 28 in the rear. Doesn't matter what brand, style or size or wheel rim width. All of those things change the dynamics, but we still seem to fall into that pressure range no matter what. Might be different in your case, but it certainly helps to experiment with pressures lower than the max.
And speaking of possible tire issues... Rotate yours front to back. Or any way for that matter, to see if it changes how or when the wobble occurs. Would not be the first time a brand new tire had a defective internal belt or tread separation that was not quite visible yet. It just happens sometimes.
My vote is still on the tires, but you can easily test all the other components yourself in the driveway with a helper.
You may have read the writeups on this test already, as it's literally EVERYWHERE here and gets discussed almost weekly if not more, but it goes basically like this:
With the full vehicle weight on the tires on the ground, have your helper sit in the truck and turn the steering wheel back and forth about a half-turn in each direction continually while you're watching from underneath. You know... All up close and personal like.
And the part about the tires being fully on the ground can not be overstated. Absolutely none of this test will work with the tires in the air like some people try. You're trying to pit the strength of the steering system against the weight of the vehicle (just like in the real world when driving) to highlight any loose bits and pieces.
Hopefully your helper is patient and in halfway decent shape, as they may have to do this back-and-forth bit for a few minutes while you rummage around under the truck looking for anything that's moving when it should not.
Start under the hood looking at the steering shaft and joints, then look at the box itself and where it mounts to the frame to make sure it's not flexing.
Then watch each rod end in succession to see if they're moving any way that the box is not telling them to. In other words, if there is play, it's worn out.
Do this with the draglink ends, then the tie-rod ends, then the ball joints, and even look at the inner edge of the wheels to see if they're moving in relation to the knuckles. This would indicate loose or worn wheel bearings.
And last BUT DEFINITELY NOT LEAST check out the upper and lower trackbar mounts. Bolts can wear, inner sleeves can wear, bushings can wear. Even the holes in the upper frame mount can wobble out over time. Any movement in the trackbar will lead to mild wandering on the road. Not always a wiggle or wobble, as you're experiencing, but a loose anything can certainly let a tire squiggle get exaggerated when driving.
Your description of it occurring mostly at 30-40 mph sure sounds like a tire issue to me. No guarantees I realize, but it's not something to ignore.
So in that light, some last things to check:
1. Make sure that your front lockouts are in the FREE or UNLOCKED position.
2. Verify that your rear driveshaft is in perfect shape. If not sure how to do this, at least remove it and drive around in 4wd High Range for a bit and see if the wobble changes or goes away.
3. Verify that nothing in the rear is loose, such as u-bolts or spring eye bolts.
That's about it. Sorry for the long-winded dissertation, but that "test" with the helper is usually worth repeating since it's helped so many truck owners over the years.
