Frontend alignment numbers
codsak
Saint Augustine
Okay guys, I took the bronco to Firestone today. what a cluster F*** !! They said they knew exactly what to do. I waited for about and hour. They brought it back out front and they said said "You are all done" , I looked at the numbers and asked how far off was the caster?? They said "Oh you can't adjust the caster" I asked did you take off the top nut on the ball joint? Her said no and he didn't see a way to do it. I told him I had just replaced everything on the frontend. He said "Ohhhhh that nut" and did not have the 4 prong socket. He asked me to come back in 3 hours. I just got back after spending 6.5 hours at Firestone and I don't have a good feeling about what they did. Here are the numbers. He told me he got the front end into spec. and that he broke the socket adjusting it. So here are the numbers. How did he do?? How do I tell if he sucked?
jmangi62
I went through this before. I have a place that's waay better on aligning the older rigs. Your numbers are all close. But I'm not a numbers guy so what the hell do I know.;D
SteveL
Huge chevy guy
Hawthorne ca
The local Firestone tried to rip one of my friends off pretty bad. I would ask around town where other 4 wheel drive or custom rod guys go. If found the big chains not much good out here for old or custom stuff.
Digger556
Your numbers aren't terrible, but there is room for improvement. First off, I assume you have adjustable ball joint sleeves. What degree offset did you install? What degree offset are your caster bushings in the radius arms?
Modern alignment numbers for a Bronco would be:
Camber: 0.25°
Caster: 3.50°-5.00°
Toe: 0.25° total toe
So, if you can take out some camber and add some caster, it would help with driveability.
Not bad. Good alignment shops are rare and hard to find. Old stuff is not common to most places. Likely never seen an old radius arm ford before, nor will he see one anytime soon. But I bet he can straighten out a Camry with his eyes closed.
Hotrodjohn
How do toe and camber numbers change on the rear? If he broke that socket its because he didn't get the ball joint loose after taking off the top nut before adjusting with the 4 prong socket. As stated above you would have to have eccentric camber adjusters for this to even change anything but preload on the ball joint.
codsak
codsak
Saint Augustine
Thanks for the info guys,I will [post a picture of the frontend to show the angle of the tires. I just don't want to wear out a set of tires on a bad frontend job. Everything is new in the frontend. Does it look like the tires are sitting correctly? If not what can I do to fix this? They look off to me .And what is preload?
Thanks as always !
Hotrodjohn
How does it drive? Does it center itself after turns? Does it go straight down the road or wander? The caster should be higher for sure according to specs. Everyone seems to want at least 4 degrees. It appears to have some normal positive camber (top of tire further out than bottom of tire) Most seem to agree on .25 to around 1 positive on this. You could reduce this by using offset spindle shims or with a ball joint eccentric sleeve to move the top ball joint out some. On stock bronco the adjusting sleeve on the top balljoint is just to put the proper downward pressure on the balljoint as it relates to the bottom ball joint. An aftermarket sleeve allows the actual position of the top balljoint to be moved in and out a little to adjust camber. Problem with that is that where you end up may not have the right preload on the balljoint and correct camber at the same time. The offset shims go between knuckle and spindle and space out the hub thereby correcting camber. These shims can be purchased in different degrees of offset.
75MIKE
NE Washington
What degree C-bushings did you go with? 7 degree is pretty common to start especially with any amount of lift.
Unfortunately he went the wrong way with the camber. Not that he was out of spec, and looks like he just went with "the book" ratings which were made 50 years ago or more.
That's why we try to shoot for less than 1 degree positive camber nowadays.
With factory perfect camber and toe-in readings, you're going to wear out front tires faster than you'd like to I'm sure.
Your caster numbers are low, but just into the acceptable range for some. My own are just about there and it drives fantastically.
Your tie-rod needs to be turned up a bit more. See the angle of the draglink's lower end where it attaches to the tie-rod? Needs to point upward more.
The "official" angle is 60-61 degrees. You may already have had it up there and the technician rolled it down, not knowing where it's supposed to be or why. Or if you put it that way, just roll it up some more.
You'll also see a result of pointing it farther up, in the alignment of the trackbar to draglink angles. They don't match right now, but will be better when you change the tie-rod angle.
Loosen the three clamps closest to the center, rotate it upward to the specified angle, then re-tighten.
Drive it around and experiment with toe-in settings to see if you find a happier place.
codsak
codsak
Saint Augustine
Yea Paul I had it turned up like you said. I will have to turn it back up. I put in 7 degree C bushings 75Mike. I don't want to wear out front tires. I have already had to rotate them once. So yes I want to get this correct. My buddy's brother works for Nascar and he said to get it close by myself with https://www.amazon.com/dp/B01EPL6BB6/ref=cm_sw_r_sms_apa_i_hZy2DbT1YNEKV . Have you ever seen this? I want to correct the the top of the tire sticking out on top. That is what is wearing the tires out. Paul what do you think about shims? or eccentric adjusters? I don't know enough here to get on the good foot. I just don't want to keep chasing my tail. Seems like most shops have no clue on how to get it right. HotrodJohn what is preloading regards to balljoints ? I have heard that a couple times.
Thanks for all the suggestions guys!
Sean
An
Pa PITT
Stephenville TEXAS
so CODSAK how does it drive..
.... I'm so RedNeck what them numbers for.
... SO I'll tell you how I was taught from about 1970 ..
We had 2 or 3 very old timers alignment shop .. So I'll tell this story again on how to alignment a Bronco . Or most other old 4x4's.
Pull your Bronco onto a very flat big piece of concrete . Drive onto it & push trans into Neutral & Let it roll forward & Stop on it's own . ''NEVER TOUCH THE BRAKES'''
... GET A Carpenter square. PUT THE SHORT end on the floor & push the long end of your square up to the top of your front tire. Top of tire needs to be leaning out about a 1/4 inch more than the bottom . Now check the other tire .
Little Tires are different than big tires .
... I'm going to leave that there .
no2 step . Get 2 pieces of plastic water pipe or METAL CONDUIT . sLIP ONE INSIDE THE OTHER . GET YOUR HACK SAW & Cut THESE PIECES .. it'll really help if you can get your wife to hold one end !!!. Now lay down on the floor & put one end of the conduit to the inside of the back edge of one tire. nOW AS CLOSE AS you can pull the other conduit out & touch the exact same spot on the opposite tire . Then do the same thing on the front edge of the tires . Back reading & front reading needs to shorter in the front than in the back .. Both reading need to be taken form the same hight on front & back YOUR TIRES NEED TO BE ''TOE IN'' IN THE FRONT OF THE TIRES.
YOUR Tie rod sleeves can be twisted in or out to change these reading ..
Now don't squall about your steering wheel being off center . You can fix that later.
.. OK Later . your steering wheel .. the 1st adjustment sleeve from the steering gear box . Adjust it one way & It'll move your steering wheel better or worse . Reverse it if it's worse..
But I like my steering wheel off set . I don't like mine for show.
.. So I keep my steering wheel at about 35* I LIKE TO DRIVE WITH MY elbow laying on the window frame & My hand on a spoke like Joe Cool... But the steering wheel is another project..
... Back to the alignment .. Back when I did mine I'd change my alignment some what & Go drive it for a day . & Bring it back into my shop the next night & Adjust it & drive it the next day . & Play again.
... no.3 I forgot... 7 degree sound like a bunch to me on my kind of close to stock rides.
..... Now this piece of information I'm going to say read several times ... This is more for Radius arms on my 1980 4x4 Bronco . & maybe 78 pickups .
... But if you can push the front end forward, It drives down the road straighter & It's easier to steer .. & If you pull the front in back ... When you twist the steering wheel it breaks faster . Sharper turns But harder to drive straight down the Hyway. .
...... Now I hope you can under stand this Statement .. This is pretty hard to tell just on paper . I need some hand jesters.
... many years ago I printed this statement .. One of the member here read it & Kept thinking about my alignment ways or terms.. So he kept trying to get his fixed in modern town .
He read my post about 20 times . & THEN PULLED UP ON A FLAT PIECE OF CONCRETE .. & STARTED ON HIS .. After he did the adjustment a few times .. He said it clicked as he drove his .
In a few day He was driving his with one finger .
... I sure wish I could remember who it was ..
.... THOSE old men used 20 ton jacks too bend those radius arms Chained to the floor..Carpenter Squares .& Elec CONDUIT Tubing . & Drive it.
Then that's normally about all you're going to get as far as caster goes, within reason.
You can actually supplement it with radius arm drop brackets (or even the ball-joint eccentrics discussed later), but adding more caster like that could run you afoul of a binding u-joint in the driveshaft. You'll have to verify your current pinion angle to see if you have any more compensation left through the normal channels.
If not, then cutting and turning the steering yokes is the only solution to get more caster.
My buddy's brother works for Nascar and he said to get it close by myself with https://www.amazon.com/dp/B01EPL6BB6/ref=cm_sw_r_sms_apa_i_hZy2DbT1YNEKV.
Yes, been around for a long time. It's for checking though, not adjusting. So you still have to make other modifications to utilize this gauge to your advantage.
It's part of the equation. Adding to the camber is the toe-in. But there is only so much you can change the toe-in without effecting how it drives.
Camber on the other hand can be changed to improve wear and still handle good. In our situation anyway. Not always the same for all vehicles, in case the subject comes up in regard to something else someday.
I think they both do their jobs. Some don't like the eccentrics, but I don't see too much trouble with them personally. However not everyone's experiences are the same, as we run into often with changes to Broncos.
Either one is available incrementally up to 1.5 degrees, and the eccentrics are more easily adjustable. You can adjust a spindle shims too, by rotating it on the bolts. But with only a very limited choice of positions and potentially big changes between them, making them "adjustable" can be finicky.
With the eccentric you simply turn it slightly to achieve your goal. This turning is what John was talking about as it might change the preload. I have found the preload to not be that precise with even a full half turn of the sleeve sometimes, so in those cases it's probably not an issue. Some setups just have more range than others.
Still, worth a shot I say. But shims are easy, and you're close enough that you would only need a shim of about half a degree on one side, and maybe a little more on the other.
The eccentrics on the other hand can also be used to gain another 1.5 degrees of caster. Even though they're considered a "camber" adjuster, if you turn it so the ball joint tilts rearward you've just increased your caster.
HotrodJohn what is preloading regards to balljoints? I have heard that a couple times.
Installing ball joints requires a final setting, using the upper threaded sleeve (stock is centered so not an eccentric, just a "tensioner" so to speak) to get the proper tension that is checked when it's fully assembled.
As said, this is the source of the concern that using an eccentric sleeve as an adjuster for parameter other than setting tension will negatively effect (or "can" effect) that original purpose. And it's true, that it might.
Having some range gives you at least a fighting chance that you can have your cake and eat it too.
Which, because this is a Bronco after all, does not always work in our case!
Because you have the shim option for camber, that's a good place to start. But getting that extra 1.5 degree of potential caster could be worth it.
codsak
codsak
Saint Augustine
Wow! this is a lot to take in. Pa PITT this is awesome!! I will have to read it several times as you said so I can take it all in. I guess my question is this. How the hell did it get so out of wack when I lifted it? I added the proper additions that was recommend to ensure proper angles of the frontend. Now I am adding shims and other trinkets. Do other people have this issue? I look at the other broncos that have a homemade lift and there tires look spot on! What gives? This is like chasing a ghost. Paul, I am going to roll the draglink up today. I did watch a couple frontend alignment videos with string and jack stands. I am going to start there and see where I am. Man.. Once this is out of whack.. its a bitch getting it back!
Paul, I moved the tie-rod. Have a look I unbolted it and rolled it up. Does that look better?
You guys are frecking awesome !!
I love it here.
Sean
It didn't. It's just that yours was set up pretty much this way at the factory.
Your camber was supposed to be between 1 and 2 degrees positive from the factory, and it is.
It does not change a notable amount when lifting.
Toe-in settings change with tire size when measured in inches, but when measured at a degree value like they do today does not. And it does not change notably due to a lift either. It might be measured on the machine, but not by eyeball usually.
Caster is what changes. A LOT!
Because the radius arms tilt when extended you change your caster towards the negative. The C-bushings are offset to compensate, but while it's enough to bring it back to original (or more in your case) that "original" was often crappy and well below expectations to begin with. General rule of thumb was that for a 3" lift you needed 4 degree bushings to bring it back to stock. The problem is that "stock" was usually very low to begin with back then. Hence the more common recommendation to go straight to the 7 degree bushings even with just a 2.5" lift.
So nothing unheard of in your case yet.
Yes, a large majority of Broncos do need this stuff. Most don't get them however, and the owner just leaves it as is, as "good enough" for them. Or "too much hassle" to bother with for a weekend driver.
Some of the additions you added have nothing to do with alignment numbers on a machine. The trackbar drop and dropped pitman arm simply bring your steering linkage back down to a workable level. This is not part of an alignment, but will totally effect your driving experience due to the changes. But nothing to do with camber, caster or toe-in.
Only the C-bushings work in that arena, and only for caster. But if your Bronco started off low to begin with, you're still going to be low even after the compensation.
This is why we are always on about trying to get an alignment reading before doing a lift. This way you know which C-bushings to order before it's lifted, or even if the C-bushings alone will be enough.
Unfortunately most people don't have that option, as by the time we start talking about it here the Bronco is already in pieces.
When it's not, either they don't want to pay twice (understandable) or just don't want to hassle (also understandable) and so don't do it.
Or we forget to mention it, which happens too of course.
Their Broncos either started out in better shape alignment-wise, or they've already gone through the same thing and have dealt with it by the time you saw their Bronco.
And what constitutes a home-made lift? I would say that 95% of all lifted Broncos were done with off-the-shelf "standard" parts, whether mixed and matched, or bought as a system. The only thing home made in those cases is that the store-bought parts were installed at home.
Just like here in fact.
And like said, some Broncos came from the factory with better settings. Things were just not that consistent at the Dana/Spicer factory apparently.
But there is also the 40 to 50 years or hard use and abuse that some go through. It's not hard to bend up a front end when bouncing around off road. Or even on the road the way I've seen some people drive!
But again, yours is in the normal range for some things. That 1.2 degrees is well below the accepted max of 2 degrees. And your caster was probably perfectly acceptable when the rig was new with skinny little bias ply tires on it and the roads were in the shape they used to be in.
And back when we didn't know better how a vehicle could actually handle if designed right in the first place for that aspect of life.
Not really. Just seems like it when it's unexpected. But much of what you're talking about right here is what we've all gone through. Sometimes multiple times.
Even without a lift, some of us that have had our Broncos for years drive around and decide to change the camber with the methods described, just to get it better than it came from the factory. Same with caster even without a lift.
Stock caster was supposed to be something like 2.5 to 4 degrees. But it was RARELY that especially in the pre-'73 years due to manual steering. More positive caster means harder steering. Even with the skinny tires that would have been unacceptable so they erred to the low side and we got stuck with 1.5 to 2 degrees of caster. Right about where you are now. It's just harder to enjoy with bigger tires and a new, higher center of gravity working against it. And you!
We'll hang in there and try to keep you from pulling all of your hair out!
Yes, much!
Pa PITT
Stephenville TEXAS
... Yap I can't imagine not under standing the front end & reading my old red neck answer .but if you can get through it a few times .. Then you realize it's easier that you 1st thought.
& As far as it getting out of wack after all new parts .. yes you can be off 3 & 4 inches fast..
codsak
codsak
Saint Augustine
Very true Pa PITT. I have read Paul's answers as well as yours. It is great! I just got the front end tool in the mail today. I have made a 1/2 and 3/4 in PVC pipe to make the measuring sticks. Its a great idea. I do understand the frontend. But when it comes to what makes it drive good and what makes it drive like shit. SO I guess that comes with time. The only way I can learn is from guys like you guys and doing it. If I learn it I want to know it. Then when I really appreciate all the great advice.
Happy Holidays!
Sean
Pa PITT
Stephenville TEXAS
i Know when I drove some of mine I'd feel something that they had said .. & That's when that light bulb goes off. Oh that's what he meant .
If the tires don't have enough toe in then it'll walk but If you have too much toe in then your tires will wear the inside edge..
Completely straight & you can have the death wobble . I like 3/8 on mine & that's a good bit of toe in.
